Hi David,
You may check on this site in resources for a Zenith 6D520 which has alignment data. It seems to be pretty much the same as the 6D525.
Hey Doc,
Thanks, I printed the 6D520 schematic. The set looks very similar to mine and should work great. I appreciate the tip. Oh, one question, where do I hook the "ground" clip from my sig gen. I think the chassis is hot on this set.
David
Hello David,
I would connect the ground clip to the radios B minus. On my 520 the electrolytic is mounted vertically on top of the chassis on an insulated electrolytic mounting plate. For alignment I connected my negative gen lead to one of electrolytic ground lugs. I don't remember if there were 3 or 4 lugs. These lugs are all connected together. One caution is in order. If your sig generator has a 3-wire cord it will be a good idea to use a 1-to-1 isolation transformer (120 V to 120V)to power the radio to prevent possible damage to the radio and/or the sig generator. I would replace C9 with a new cap of the same value and a voltage of at least 1000 volts.
An isolation transformer is always a plus, but by following the above directions, you may align your radio successfully without one even if your generator has a 3 wire cord with the ground wire connected to its chassis. I've aligned radios in this way many times with my generator, though as a precaution I disconnected the ground wire of its cord from its chassis. This way I could also align radios with chassis which are connected directly to the line. In this case, when I removed the ground wire from my generator, I connected a condenser to the chassis from the ground wire instead. Again, even with this modification, with either type of AC-DC radio (hot chassis or condenser isolated chassis), it is good practice to plug in the radio so that the chassis is on the neutral side. This eliminates shock risk and reduces hum problems.
If you do not quite understand what I have said above, it is wise to use an isolation transformer at all times.
