When I encounter asbestos in an antique radio I do not remove it. Instead I dilute regular white wood glue about 50% with water, and apply it to the asbestos with a brush or spray bottle until it quits soaking it up. Once dried, this will seal and encapsulate the asbestos. This procedure may not satisfy EPA or OSHA standards, but from a practical standpoint will prevent health risks from the asbestos fibers as long as it remains undisturbed.
Poston
:My AC/DC radio phono had a strip of asbestos under the chassis and glued to the wooden cabinet. I removed it and thinking foil tape would be a good replacment, used it to reflect heat. No radio reception! Works fine wihout any metal underneathh, but as soon as I cover the bottom with any metal I lose my radio reception. Phono works good otherwise. Looking for a non-metalic replacement now for the asbestos.
If you can locate some Nomex (r) material, that's what is used for hi-temp transformer insulation. Hobbyists use it to insulate model airplane gas engine compartments.
http://www.amainhobbies.com/product_info.php/products_id/4410
Good Luck... Rich
I removed the asbestos from my Zenith 5-G-500 a long time ago when I was parinoid about it like everyone else. I've been operating the radio ever since with no asbestos on top of the wood panel that the chassis sits on. This radio is an AC-DC-Battery radio with hot resistors underneath it. Though one could start a fire if there was a short, no fires have started. I keep the resistors far away from the wood.
Again, though, unless you work in an asbestos factory or make a career out of the Navy in 60 year old battle ships, there's no need to worry about the stuff. It doesn't jump out and climb into your lungs. Unless you agitate it a lot, it sits there and does nothing. Asbestos takes lives. Asbestos also saves lives.
Regarding battle ships, my uncle made a career out of the navy, and died of asbestosis. They used tons of asbestos in the old ships, and since a ship is always moving around, the asbestos is always being agitated. The asbestos in a radio is small, and even if you tote the thing around, you're not going to agitate it much. Taking the chassis out repeatedly may agitate it. You can spray it with a very thin mist of clear lacquer. This will hold the fibers in place, though lacquer is not fire proof, so try not to saturate the asbestos.
