Does the speaker have a field coil? This is a large coil of wire in back. Is so it needs to have the field powered for a magfnet.
:I decided to replace the speaker in this redio with a salvaged speker from a Silvertone Model 20. That speaker has the transformer attached to it, whereas the Sonora has its transformer under the chassis. I tried snipping the wires between the transformer and speaker of the Silvertone and hooking the output leads from the Sonora transformer to it Silvertone speaker. I know the Silvertone speaker is good. Why does this setup not work? If I replace the Silvertone speaker with a generic 8 ohm speaker it works. What gives?
Also, in my experience I have found that many of the speakers of then, especially the smaller ones, are usually 3.2 ohm speakers. If you can't get that Silvertone speaker to work, try a 3.2 or 4 ohm modern speaker vs. an 8 ohm. Whichever one is loudest and has the best tone is the correct speaker.
:This is all too obvious, but just to be safe, I'll recommend that you be sure that you're connecting to the speaker voice coil and not the secondary of the output transformer. If you were going for the voice coil but accidently wired to the transformer secondary, you'd get no sound. Are you sure that the Silvertone speaker works otherwise? Connect a battery across the voice coil and see if it clicks.
:Also, in my experience I have found that many of the speakers of then, especially the smaller ones, are usually 3.2 ohm speakers. If you can't get that Silvertone speaker to work, try a 3.2 or 4 ohm modern speaker vs. an 8 ohm. Whichever one is loudest and has the best tone is the correct speaker.
:Thomas
