I would not expect any interaction between the FM and the AM/SW tuning normally. I would have to see the schematic to be sure.
Again, not being familiar with your set I can't be sure but FM uses a totally different detection method than AM. So I might be inclined to look at the FM discriminator (detector) for distortion problems. These sometimes need to be aligned.
Tony
:Hello, I am having some really wierd things happing with my telefunken opus 7. I hooked up an antenna to the shortwave and found that I get a lot of stations around the world, but there is a dial for sw/am and a dial for fm. When I find a sw station and I turn the fm dial it affects the tuning on shortwave for better or worse. Why is this happing? I also notice the sound is better on sw, less destortion. When I tune in a fm station I can get it in clear, but there is destortion when I turn up the volume. Is there a relationship to the two bands?
:Thanks
:David
I was going to suggest that as a possibility, but it seemed so unlikely :).
Tony
:In some German radios the FM tuning cap was parallelled to the normal larger AM tuning cap to function as a fine tuning on SW.
:David ,I should have answered your second question too.I'm not sure how experienced you are,but here it goes:What you ALWAYS should do on these radios from the 50's is to replace the waxed paper caps in the LFstage.Since it's a Opus7 in your case it has a PP output stage(part of EABC80,EC92 and two EL84's in push pull).There are three 0.022 uF in this stage-replace them!!Don't even bother to measure them,since they have a leakage problem,which causes more and more leakage as time passes and causes the output valves to draw more and more current and could lead to more serious problems.
:If you don't have the schematic ,tell me and I'll help you.
If you are in immediate need of the schematic of that unit, here it is in a very enlarged version:
Right..HERE
Otherwise, for further data to all of the units smaller framo-stats, giggly pins and bi-furcated tensioning adjustments,
they are being forwarded to you also.(Since I see that you supplied a "hot" e-mail
addee)
:Hi,
:Do you still have the photofact for an OPUS 6? Would you sell it if you don't need it? Would you make a copy? I just got an Opus 6 and need some literature.
:Thanks,
:Emery
