To look up tubes in a radio a model number is needed. You can find schematics for Temple here which will show tube numbers.
http://www.nostalgiaair.org/Resources/412/T0000412.htm
:Ok you guys here are the tubes in my radio. Two 51's two 24's one 47 and one 80. Any help would be appreciated!
Richard
::Mark: Looked in the Mallory Radio Encyclopedia which usually makes short work of getting the model from the tube lineup. In this case there was no close matches much less an exact match. Wondering if this could a non-US radio?
::Richard
A 51 is same as 35?. Some are marked 35/51.
There are other manufacturers which used those tubes. Although not exactly the same check Philco Model 70.
:Not sure of origin. The cabnet has a tag on the back that says Genuine Adler Royal Cabnet. Adler Mfg. Co. Louisville Ky. I don't know if this is any help or not.
:::Mark: Looked in the Mallory Radio Encyclopedia which usually makes short work of getting the model from the tube lineup. In this case there was no close matches much less an exact match. Wondering if this could a non-US radio?
:::Richard
Temple generally used UY-235's rather than the 551 super control tetrodes. Check for a schematic that uses a couple of '35's, a pair of 24's a 47 and an 80
Richard
