EICO 723 Choke, swinging 2-25h
12/29/2005 10:09:00 AMRon
I am trying to find a rep[lacement for a 5-25h choke, EICO part number S34003. The one in the transmitter now has a loud buzzing sound. I think it is going out.
12/31/2005 12:29:13 PMNorm Leal
Hi Ron
Loud buzzing is not a problem. A choke like this has a lot of ripple across the winding. Try tightening screws holding laminations together. Noise you hear are laminations vibrating. If tightening screws doesn't stop the noise coat the choke with varnish.
:I am trying to find a rep[lacement for a 5-25h choke, EICO part number S34003. The one in the transmitter now has a loud buzzing sound. I think it is going out.
12/31/2005 2:17:01 PMRon
Thanks Norm I will give it a try. I will let you know if it works or if I have any more question.
:Hi Ron
: Loud buzzing is not a problem. A choke like this has a lot of ripple across the winding. Try tightening screws holding laminations together. Noise you hear are laminations vibrating. If tightening screws doesn't stop the noise coat the choke with varnish.
::I am trying to find a rep[lacement for a 5-25h choke, EICO part number S34003. The one in the transmitter now has a loud buzzing sound. I think it is going out.
1/2/2006 11:28:12 AM
Norm,
That worked. I added six screws through the choke and tightened them down. I only have a low humming sound which is very acceptible.
Thanks again.
Ron
:Thanks Norm I will give it a try. I will let you know if it works or if I have any more question.
::Hi Ron
:: Loud buzzing is not a problem. A choke like this has a lot of ripple across the winding. Try tightening screws holding laminations together. Noise you hear are laminations vibrating. If tightening screws doesn't stop the noise coat the choke with varnish.
:::I am trying to find a rep[lacement for a 5-25h choke, EICO part number S34003. The one in the transmitter now has a loud buzzing sound. I think it is going out.
