What I think I am seeing on my current project is a poor connection in my tube sockets as changing tubes makes a difference however readings are not consistence when I put the original tubes back in.
Also for those who have more experience then me, what is the probably that I may need to re-solder tube pins or should this be a standard practice.
Current project is a Zenith 6-S-229
Larry Goldy
Shouldn't be necessary to automatically resolder connections to sockets. If there is a bad connection which you detect by visual inspection or wiggling, the you can remelt the connection and perhaps apply a little fresh solder.
If you hear crackling noise in your speaker, this could be due to a loose grid or plate pin lead inside of the tube pins (suspect more than just the control grid when working with multi-grid tubes). It is more likely a faulty component such as a leaky and/or arcing condenser, or a faulty resistor (broken internally....possibly visibly cracked or charred)...maybe even the volume control. It could also be faulty chassis wiring or a fault in the power transformer, field coil, etc. It could even be a short between tube elements within the tube. The least likely cause would be a loose tube to pin wire. Check all items in the order which I have given them. If you haven't replaced condensers, then don't even think about tube pins unless one is obviously at fault--you can see the wire loose in the pin.
Though resoldering all of the tube pins is fairly easy, it usually is unnecessary. It ruins their appearance, as the original solder was buffed by some means to the nice round shape. With a glob of solder at the end of the pin, it'll make insertion of the tube into the socket difficult. Simply put, it's extra work that doesn't need to be done.
Point well taken, I guess I was a little paranoid about good connections and will exhaust other avenues first before resorting to soldering tube pins.
Larry
