I remember this topic a while back. The 12LP4 was used pretty much used by everyone building TV's then. Dumont used a 12QP4 and I recall the 12UP4 was a Zenith type. I don't know where you are located but I have a 12LP4 still strapped to an Admiral chassis with no cabinet. You could have the tube but I would be afraid to ship it. I don't have any way to test it but it is still under vacuum. Any chance you are located near S.E. Pa? I would give it to you.
Fred
WA3KIO
:Hi All!
: I'm desperately searching for a good used or replacement for a 12UP4A or 12LP4A CRT tube, I've had no luck at this point, does anyone know of anyone or have one of these tubes, or a replacement for it.
:Mark
I too and seaching for a 12LP4 espectially one that has a focus coil and yoke attached to it...
The one you have sounds perfect, if you would be willing pack it up and send it to me out here in Billings, MT 59101 I would gladly give you $100.
Stan
btw you can reach me directly @ everstan@bresnan.net
You know I asked my local tv repairman who is fairly knowledgeable and seem to think it was a occiliscope tube??? because of the strange numbering...he also indicated it has to end in p4 to work as a replacement.
PS...I saw that one on ebay too.
For instance: a 5BP1 is a very common and rather early/primative oscilloscope tube. A 5BP4 tube uses the same electron gun configuration, but uses a white television phosphor.
The first digit often refers to the screen size. Thus, if you have a 12 or a 19, this doesn't usually mean that the filament operates at 12 or 19 volts as with radio tubes. A 5 of course means that my 5BP1 has a 5 inch screen.
The second digit(s) refers to the electron gun configuration.
