Don't plug in this radio. With those tubes it might be a 6 volt DC radio? Vibrators are only needed in radios operating off of DC. 6A7 & 38 have 6 volt heaters. 15's are 2 volt and may be wired with filaments in series. A 30 tube uses 2 volts DC on the filament.
Someone could have modified your radio? Check where power wires connect. Crosley 625 is listed in my books.
:Hope someone can help clear this up. Just found a Crosley model 625 tombstone and I can not locate the schematic on this site or on my Rider's CD. What confuses me the most is that it is an a.c model with a vibrator. I have never heard of that combination. The metal i.d tag on the chassis and the stamp on the cabinet both say it is a model 625 and the label showing the tube line up matches the chassis. The tubes are # 15(3), 6A7, 38,and 30. Many thanks for any help.
:Jon.
But anyway, it must be a farm radio with a vibrator to supply the B+.
Many of these sets were later converted for AC operation. I've encountered a couple like that, and they were pretty well butchered by whoever made the conversion. You ought to be able to tell if the set has been converted - but maybe somebody started the conversion and didn't finish it.
If, in fact this is a converted farm radio, then you'll not find a factory schematic. It's kind of like finding a Model T Ford that some kid in the '50s dropped in a V8.
Norm/Doug, Thanks for the responce. The set looks like it was factory wired with an a.c. cord(very old cloth covered)through what also looks like a factory fuse. The cabinet is stamped 625E so I guess that is what it originaly was. If I get a copy of the schematic I will re-convert it back the way it was. It was those # 15 tubes and the vibrator that got me wondering, a lot like several zenith 6 volts I have. Again, many thanks for your help. If anyone has the schematic for the 625E please forward it to my email address. thank you, Jon.jongirolami@aol.com
If I remembered the model number, you all could see the schematic. It actually was originally made to be a dual power supply radio.
Doug, You were right on the money. After a closer look at schematics, this is a model 6B1,Battery Six. When I pulled up the Riders reference for a model 625 I saw what I thought was a # 80 rectifier tube when in reality it was the part number for the vibrator. Also the part # for the # 15 tubes is 75 which further made me think this was the wrong schematic. The radio now looks to be all original-even the fuse. Have not run across one with a fuse from this era-got to learn something new. Still don't understang the heavy a.c. cord though. Again many thanks, Jon.
When I was a kid, I only knew one family that could afford this system. There was a separate building behind their house for the generator, and it looked a lot like the Lincoln welding machines that I became familiar with in later years. I could be mistaken, but I believe the unit would start up automatically when a light in the house was turned on.
Billy, Thanks for the info, now that I have found the schematic, it shows that the radio is all original, just someone put an a.c. plug on the end of the battery cables. Maybe someone set up a 6 volt battery with an a.c. outlet for some sort of reason. There are no changes to the circuit to handle 32 volts. I have a couple of the 32 volt sets that I converted to a.c. only so that they could be played. I do not normaly change radio operating voltages but I am not smart enough at this stuff to make a 32 volt supply. Now all I need is to find out what kind of knobs it had, the ones on it know are of several different types. I would like to run across one of the 32 v. generators but I think the neighbors would object to the noise. Jon Girolami
