We think of iso xfmrs as ideal 1:1 xfmrs. Well, there is certain voltage regulation thru any xfmr. I think some manufacturers try to account for this by increasing the ratio a little.
Your 250VA xfmr should have plenty of capacity for most any tube-type radio. I think mine is 500VA, but it's oversized for most of what I use it for.
Try this: plug a load into the secondary - a good-sized radio, a soldering iron, etc. Measure the primary and secondary voltages. They'll probably be closer than when the xfmr is unloaded.
Not to worry.
Okay you guys thanks a lot. I did put it under mild load (25w solder iron & 30w radio).. still 5v higher on 2ndary but I understand.
I was just a little concerned as it semms a bit 'toasty' to the feel.. with no load. In fact I just measured it.
( lol... after first blowing the fuse on my digital multimeter cause I had the probe on the LOW a.c. amp scale (4oo ma max) not the 10 amp a.c scale. scale...ooops)
Anyway...I see that it draws 200 ma with no load on the 2ndary.
[Now actually the meter should not have blown the fuse because the draw (200ma) is only half the max (400ma)for that scale..but I guess the inital jolt and some juicy back-EMF while making intermittent contact is what did it.]Well live and learn. Live being the operative word there.
Speaking of life and living... safety being the original goal here...I took things to the next step.
So while I was that far in to my 'mad-scientist' spark-making, fuse-blowing role.. I decided to see how much life-saving isolation it actually affords me.
So I measured each side of the 2ndary to ground. One side shows 40v ac and the other shows 120v ac.
40 volts I can see.. phantom or whatever but 120? Well that scares me a bit. So I decided to see how real it is.
So I dug out an old porcelean light socket and put a light bulb in there and put one side to the isolation xformer 2ndary and the other side to ground.
Well just like that sexy blonde in your dreams that disappears so quickly as you awake....sure enough... nothing... the bulb won't light and the voltmeter that was displaying 120 volts at that same point NOW disappears.. and it shows zero volts! Great!
Ahhh saftey achieved ... even if this self/training lesson cost me a fuse for my meter.
Hey...At least there was a nice new spare fuse tucked right in there near the holder.
I guess Radio Shack knows their audience!
but it has the same 2 separate amp sockets both fused and rated the same as my RadioSchak model
Ok great Doug:... I see now, as I look up the Fluke 179:
That although , just like mine it has 2 separate fused amp jacks: a 400ma and a 10amp.... however very much un-like mine your specs claim a 20 AMP overanging for 30 seconds!!! Wow that's the really great part. That's certainly gonna save the world's supply of edangered fuses that's for sure. lol
