Crosley 601 uses 5 volts tubes and a dropping resistor. Use a #40 lamp or for more light #46. Both are 6 volt lamps. The 40 draws .15 amps, 46 draws .25 amps.
:What is the correct pilot light bulb (screw base) for the Crosley 601 Bandbox battery set? Thanks
