Magnavox Micromatic Record Player
12/7/2005 8:52:03 PMGinger Duquette
I just located the name of the stereo console I am look for the date of manufacture on. It is: "Astrosonic Series". It is a solid state stereo high fidelity, in a walnut cabinet. The model number tag has been partially obliterated (rubbed ~ and most of the identifying numbers are gone), but I believe the last three digits are 628. I'm very interested in finding out what year in which this stereo was manufactured (made in England). Can anyone help?
12/7/2005 9:10:52 PMBill VA
Hi Ginger,
The turntable was made in England, not the whole set. It would be extreme luck if someone comes up with data on just what you have. It's most time hard when you have model number. You really need to remove the back and gather up the numbers stamped on the tuner and elsewhere. You then have a better chance of identifying it.
Bill VA
:I just located the name of the stereo console I am look for the date of manufacture on. It is: "Astrosonic Series". It is a solid state stereo high fidelity, in a walnut cabinet. The model number tag has been partially obliterated (rubbed ~ and most of the identifying numbers are gone), but I believe the last three digits are 628. I'm very interested in finding out what year in which this stereo was manufactured (made in England). Can anyone help?
8/13/2006 2:30:49 PMjoseph gamble
:Hi Ginger,
:The turntable was made in England, not the whole set. It would be extreme luck if someone comes up with data on just what you have. It's most time hard when you have model number. You really need to remove the back and gather up the numbers stamped on the tuner and elsewhere. You then have a better chance of identifying it.
:Bill VA
::I just located the name of the stereo console I am look for the date of manufacture on. It is: "Astrosonic Series". It is a solid state stereo high fidelity, in a walnut cabinet. The model number tag has been partially obliterated (rubbed ~ and most of the identifying numbers are gone), but I believe the last three digits are 628. I'm very interested in finding out what year in which this stereo was manufactured (made in England). Can anyone help?
8/13/2006 10:57:28 PMBill VA
::Hi Ginger,
::The turntable was made in England, not the whole set. It would be extreme luck if someone comes up with data on just what you have. It's most time hard when you have model number. You really need to remove the back and gather up the numbers stamped on the tuner and elsewhere. You then have a better chance of identifying it.
::Bill VA
Joseph, read my reply to Ginger. This is a must do. At least before I can get anywhere identifying Magnavox dates. And it does not always work.
Bill VA
:::I just located the name of the stereo console I am look for the date of manufacture on. It is: "Astrosonic Series". It is a solid state stereo high fidelity, in a walnut cabinet. The model number tag has been partially obliterated (rubbed ~ and most of the identifying numbers are gone), but I believe the last three digits are 628. I'm very interested in finding out what year in which this stereo was manufactured (made in England). Can anyone help?
3/4/2008 11:56:54 PMmiguel
:::Hi Ginger,
:::The turntable was made in England, not the whole set. It would be extreme luck if someone comes up with data on just what you have. It's most time hard when you have model number. You really need to remove the back and gather up the numbers stamped on the tuner and elsewhere. You then have a better chance of identifying it.
:::Bill VA
:Joseph, read my reply to Ginger. This is a must do. At least before I can get anywhere identifying Magnavox dates. And it does not always work.
:Bill VA
::::I just located the name of the stereo console I am look for the date of manufacture on. It is: "Astrosonic Series". It is a solid state stereo high fidelity, in a walnut cabinet. The model number tag has been partially obliterated (rubbed ~ and most of the identifying numbers are gone), but I believe the last three digits are 628. I'm very interested in finding out what year in which this stereo was manufactured (made in England). Can anyone help?
2/7/2007 7:59:46 PMElizabeth
:Hi Ginger,
:Bill VA
Elizabeth bos/ma:
Hey i too will like to have help in knowing what year is the record player that i have, as for the model no. 1sc601 or 1sc60i and w60318.02 (i think).
10/7/2007 2:18:26 AMomar tx
::Hi Ginger,
::Bill VA
:Elizabeth bos/ma:
:Hey i too will like to have help in knowing what year is the record player that i have, as for the model no. 1sc601 or 1sc60i and w60318.02 (i think).;;;
:Hey Elizabeth i have a model w60318.02 its in purty good condition and im restoring it my self i foud it in an ally. Im locking for the the part that turns the weall i put i apart and it was deteorated and doenst let i turn .. by the way i found the model number under the rubber were you put the record you could just take it off an double check i couldnt find it any were else.. email me at guadian_23@hotmail.com so we could share info.. thank you
