Want a battery radio converter?
12/5/2005 2:20:57 PMThomas Dermody
Interesting item for those of you who would like a vintage item. Probably needs rebuilding. http://cgi.ebay.com/Silvertone-power-shifter-Tube-Radio-Battery-Antique_W0QQitemZ5838418711QQcategoryZ294QQrdZ1QQcmdZViewItem
12/5/2005 3:41:18 PMRadiodoc
:Interesting item for those of you who would like a vintage item. Probably needs rebuilding. http://cgi.ebay.com/Silvertone-power-shifter-Tube-Radio-Battery-Antique_W0QQitemZ5838418711QQcategoryZ294QQrdZ1QQcmdZViewItem
Thomas,
I have one just like it. It is a pretty simple device and works surprizingly well. It has a power transformer with two secondaries. One is the high voltage winding feeding a selenium diode and a 1500 ohm resistor with electrolytic on both sides of the resistor. The low voltage winding feeds a full-wave selenium rectifier to a choke with large electrolytics on input and output of the choke. There are taps on the low voltage secondary and a socket and plug to adjust for the number of tubes in the radio. It works quite well, however, it injects some hum into the radio.
12/5/2005 6:13:32 PMDoug Criner
There's an article in the November '05 Antique Radio Classified magazine about this Sears "Powr Shiftr." It first appeared in Sears' 1942 catalog.
