Richard
Bill VA
:I think "reactor" is another name for a choke or coil.
If you cannot repair any troubles, new transformers may be found at www.tubesandmore.com. They are not very expensive. You can go with a universal push-pull interstage transformer. Unless you know the AC impedances of the original transformer, this is the best way to go. You may not find a push-pull transformer that has a single primary (not center tapped). In this case use one with a center tapped primary and use only half of the primary. For both the primary and the secondary, use the tap that produces the nicest audio. Too large an impedance on the primary will cause the audio to be mushy and distorted (perhaps, but not necessarily). Too small an impedance on the primary will cause a lack of bass. The opposite holds true with the secondary. Neither too large nor too small will likely cause distortion when dealing with the secondary, though too large a setting may cause too much gain.
If you know the DC resistances of both your primaries and your secondaries (if one side of the secondary works, the other should be the same), you may simply try matching these on the new transformer. DC resistances aren't usually given on audio transformers, but can be found easily enough by using your meter. However, depending upon the wire used and the amount of wire necessary due to different iron size and count on the new transformer, using same DC resistance settings may not produce same results.
Transformer impedance settings are not that critical for a radio of this type, so just go about it in a trial-and-error way. Be sure, of course, that whatever you choose as your impedance for each secondary half, is the same for both secondary halves. They should match.
T5 is an interstage audio xfmr. I'm a little surprised that both ends of the CT secondary are open, so double check your work.
You could give this replacement xfmr from AES a whirl: P-T124E @$23.95. A cheaper possibility is their P-T124D @ $18.95. RadioDaze has the same models for the same price. Like Thomas says, there is a relatively wide range of ratios that will produce satisfactory performance.
