Majestic Mdl 130-A Chassis
12/1/2005 3:33:23 PMWarren Guinn
I came across the complete chassis of a 130-A Majestic in my attic and was wondering what it may be worth?
(no speaker)
Thanks for any info,
Warren
12/3/2005 6:21:11 PMJoe Ferris
:I came across the complete chassis of a 130-A Majestic in my attic and was wondering what it may be worth?
:(no speaker)
:Thanks for any info,
:Warren
Who is the manufacturer??
12/3/2005 7:26:50 PMDoug Criner
Here's the schematic: http://www.nostalgiaair.org/PagesByModel/977/M0039977.pdf
I found a Model 130 (but not 130A) listed in one of my guides. It's described as a lowboy console, c. 1930, value $110-130.
When you say you have a "complete chassis," does that mean there is no cabinet? The above value would apply to a complete radio, including both chassis and cabinet.
There have been several manufacturers that used the "Majestic" moniker, including Grundig, but yours seems to be a Grigsby-Grunow.
12/9/2005 11:07:35 PMDave Kasabo
:Here's the schematic: http://www.nostalgiaair.org/PagesByModel/977/M0039977.pdf
:I found a Model 130 (but not 130A) listed in one of my guides. It's described as a lowboy console, c. 1930, value $110-130.
:When you say you have a "complete chassis," does that mean there is no cabinet? The above value would apply to a complete radio, including both chassis and cabinet.
:There have been several manufacturers that used the "Majestic" moniker, including Grundig, but yours seems to be a Grigsby-Grunow.
12/9/2005 11:11:29 PMDave Kasabo
::Here's the schematic: http://www.nostalgiaair.org/PagesByModel/977/M0039977.pdf
::I found a Model 130 (but not 130A) listed in one of my guides. It's described as a lowboy console, c. 1930, value $110-130.
::When you say you have a "complete chassis," does that mean there is no cabinet? The above value would apply to a complete radio, including both chassis and cabinet.
::There have been several manufacturers that used the "Majestic" moniker, including Grundig, but yours seems to be a Grigsby-Grunow.
I have restored a Majestic 130-A. Your radio, a 1930 majestic model 130-A is a Tuned Radio Frequency (TRF) receiver. It was designed in 1929 by the design team at Standard Radio in Toronto but built at the Grigsby Grunow plant in Chicago. The same radio chassis is used in the models 130, 130-A, 132 and 230. There were two cabinet styles of the console (floor model) radio; one from Canada and one from a furniture manufacturer ion Chicago. The model 130 cabinet was built in Canada and the 130-A cabinet was built in Chicago. The 130-A cabinet is an African ribbon mahogany cabinet with fiddleback mahogany curved front panels. The model 130 is rather plain and unremarkable.The radio can be set for 60 cycle power operation or 25 cycle operation and is fused. This was unusual in the 1930’s as most of the radios produced until 1940 were not fused.
12/10/2005 2:03:13 PMDoug Criner
Dave - sounds like a very interesting set!
1/2/2006 11:17:56 AMMinel Torres
:::Here's the schematic: http://www.nostalgiaair.org/PagesByModel/977/M0039977.pdf
:::I found a Model 130 (but not 130A) listed in one of my guides. It's described as a lowboy console, c. 1930, value $110-130.
:::When you say you have a "complete chassis," does that mean there is no cabinet? The above value would apply to a complete radio, including both chassis and cabinet.
:::There have been several manufacturers that used the "Majestic" moniker, including Grundig, but yours seems to be a Grigsby-Grunow.
:I have restored a Majestic 130-A. Your radio, a 1930 majestic model 130-A is a Tuned Radio Frequency (TRF) receiver. It was designed in 1929 by the design team at Standard Radio in Toronto but built at the Grigsby Grunow plant in Chicago. The same radio chassis is used in the models 130, 130-A, 132 and 230. There were two cabinet styles of the console (floor model) radio; one from Canada and one from a furniture manufacturer ion Chicago. The model 130 cabinet was built in Canada and the 130-A cabinet was built in Chicago. The 130-A cabinet is an African ribbon mahogany cabinet with fiddleback mahogany curved front panels. The model 130 is rather plain and unremarkable.The radio can be set for 60 cycle power operation or 25 cycle operation and is fused. This was unusual in the 1930’s as most of the radios produced until 1940 were not fused.
:Dave: Please help me identified a Grundig Magestic Radio. There is no back cover, the number of the chassis is 104060637. In the botton of the cabinet it has 1040 110/111. This radio look similar to Grundig 3090/56. Please send the information as soon as possible. There are two tubes missing and I need to identified the tubes.
Minel
3/25/2007 11:09:50 PMktinstall
2/22/2007 5:43:46 PMi bertone
::I came across the complete chassis of a 130-A Majestic in my attic and was wondering what it may be worth?
::(no speaker)
::Thanks for any info,
::Warren
:Who is the manufacturer??
