This set seems to have a loop antenna, L1, wound on a ferite core. Check for continuity through L1 - its winding resistance is listed at 1.3 ohms. Put your ohmeter leads across the tuning cap, C1.
Doug,
Putting my ohmeter across C1 on the printed circuit points and measuring L1 resistance I read 1.1 ohms. Also I didn't mention, all the tubes measure good emission.
Phil
Phil,
If you have a station close to 1400 KHz, you may tune it in and try adjusting the antenna trimmer slightly for maximum sound output.
