Please help if you can. I wont turn it on until I know that the filter capacitors are connected correctly. I don't have a spare 35Z5 lying around.
Dave...
http://www.hupse.nl/radio/frameset.htm?philco_1201.htm&ContentFrame
The one I have is the code 121. Code 122 is in Riders.
I have a 50X6 and a 35L6 (someone replaced it with a 50L6). Problem solved.
I hope that this helps.
Dave...
:Hello All,
: When I took a look at the service data in volume 15 of Riders, I noticed that the set I have in front of me is different from the one in the book. Does anyone have the schematic for the "other" Philco 46-1201 chassis?
: There seem to be some problems with the way the filter capacitors are connected. There is a positive lead from one connecting to the negative of another. Also, the negative from the other two does not directly connect to the chassis. It connected through a resistor. Two seem correct, one seems wrong.
: Please help if you can. I wont turn it on until I know that the filter capacitors are connected correctly. I don't have a spare 35Z5 lying around.
:Thanks,
:Dave...
