If anyone can ID these values for me it would be very much appreciated. Thanks.
Dean
For more information. I found the part numbers from other schematics. The Howard part numbers of the capacitors are P-1802, P-1803, and P-1804. By looking at other Howard Schematics, I found that a 1802 is a .5mfd, 1803 is a 1.0 mfd, but still at a loss for the 1804.
First a question - I wonder why Howard did not show component values on the schematic, just Howard part nos? Oh, well. Schematic at: http://www.nostalgiaair.org/PagesByModel/055/M0040055.pdf
Regarding the value of cap 1804. This cap is in parallel with 1803, which you have determined is a 1uF, correct? (Double check that.)
These two caps seem to be serving as a cathode resistor bypass for the three RF stages. I don't know why 1uF isn't plenty sufficient, unless there is some RF issue involving the physical arrangement of the wiring. Maybe some of the gurus here can shed some light on this.
But anyway, I'd try a 0.1uF for cap 1804 and see how it works.
Hi Doug. Thanks for the help. I will try a .1 and see what happens. I don't know why they would have them installed in parallel like that except it probably has to do with shielding issues, as the two caps are in separate compartments of the radio. As far as the schematic goes, it is weird that they only put the Howard part numbers down instead of the values. If you look at the other Howard schematics a lot of the older ones do the same thing. Unless you have a parts list from Howard, you are pretty much sunk except for guessing. Thanks again!
