Many of the schematics here are a little blurry. I have a CD of Rider's, which is no better.
I have a pretty decent computer monitor, and have found that the best resolution is obtained by jacking up the %-blowup within the Adobe pdf viewer. Works better than printing out the schematic, and then trying to look through your bifocals.
Is there a particular component that maybe I can blow up on my monitor and try to help you with?
Does the dual cap have three or four leads coming out of it? If three, then one is a common for both caps. From that you could identify the node on the schematic where both caps should be shown schematicly hooked to. Then look for the two caps from there?
When you started working on the radio, was the dual cap hooked up?
Don
