thanks for the reply jim i have a few also but none have the on off switch or the 1/4 inch shaft i need i need one around 5 k mostly but would like to have a few in the 1 to 10k range i'm still looking but haven't had much luck so far.butch
hi doug i have a couple of 30's sets which had bad vol. pots i replaced them with carbon pots and while they work they don't work right .these are the type that hook to the ant. coil and as i remember have b + on one side its been a while since i looked at them so my mind isn't clear on it.anyway someone told me that carbon pots don't work good with this type of circut and that was my problem now that i think about it maybe something else is wrong i just thought i'd set them aside until i had some ww pots and see.one of these was a crosley mod. 172 the other was a majestic but i forget the mod. of that and am too lazy to walk out to the shed through the snow right now.i have worked on these tube sets for a few years and usually can fix them but i am not a expert by any means so mostly when i get stuck i rely on advice from these forums, every time i think i am getting good i run into a new problem that baffles me, well if i keep at it long enough i may get good someday if i live long enough although there are many times i think i should stick to plumbing which is what i do for a living but its not as much fun. butch
