ABSOLUTELY NEVER SHOULD YOU BRING ANY DIRT OR METAL FILINGS NEAR THE METER WHILE IT IS OPEN. I cannot stress this enough. This is a rule from God! If you bring any dirt or metal filings, especially metal filings, they'll get into the meter and ruin performance. Metal filings (steel and iron) will not be easily removed from the magnet.
Be extremely careful with the hair springs. If you bend them, meter calibration will be thrown off, and the meter may possibly operate irratically. Though the meter should be lubricated at the bearings, I cannot recommend that you do this unless you have a watch repairman's skill. If you get an excessive amount of oil on the bearings, it will drip down onto the hair springs, which will cause them to stick together, causing irratic meter operation. The only oil to use is the lightest. Trumpet valve oil fits this category. WD-40 does as well, but is not long lived. Still, it lasts for a year or so, and considering that your meter hasn't been lubricated in years, this is probably a good thing. 3-in-1 oil is okay, but a bit too thick. It'll work, but it may run onto the hair springs. Apply by soaking the tip of a tooth pick. Apply a film of oil, not a drop. Rub it onto the shaft point at each bearing. If you use too thick an oil, meter may not respond properly. Normally, however, it'll respond alright, but it may be slowed down.
Though there are meters which are lubricated, there are indeed meters which are designed to run dry. As I said before, I recommend that you DO NOT lubricate your meter because of trouble with oil getting onto the hairsprings. I have lubricated meters with much success, and I know of several which are designed to be lubricated, but to be on the safe side, you probably shouldn't lubricate any meters. Also, WD-40 is comparable to the lubricants which they use in fine watches and clocks. My uncle was a top watch repairman and jewler for over 70 years, so I have an in on this information. He has repaired my 1941 Bulova 10AX movement many times, and whenever he repaired it or simply cleaned it, it has always kept perfect time. Unfortunately the slightest amount of moisture (sweating) is enough to leave deposits on the gears which upset the time keeping. Also, accidently dropping it on the floor is enough to throw the balance wheel out of position, so you can see why I have had it repaired many times. I keep the watch on the shelf now for the most part and wear an inexpensive battery watch which keeps far superior time without any maintainence. Also, my uncle has died. Other jewlers I know of with just as much expertise charge prohibitive prices. A superb balance wheel/cleaning/mainspring job I had done recently cost me over $140, the price of a rather expensive battery watch. The watch needs a cleaning again, and I'm not up to paying any more money.
Hopefully someone on here will have a good suggestion for static. I can say try an anti-static record cleaner (if you can find one). You could also try connecting a spring wire to the meter's metal frame which would contact the plastic face in some inconspicuous place. This may or may not help collect the plastic's static charge and neutralize it with the meter "works," which happen to be electrically connected to the needle.....which would then neutralize the needle as well. If this solution works, I think that this would be a more permanent solution than anti-static record cleaner.
Another solution would be to wipe the plastic rear-side with a film of plastic friendly oil. However, this is a very poor idea, as it may affect visibility and it may collect dust, though dust shouldn't be getting into your meter.
