Your radio should have plenty of volume. It has 2 6C5 audio stages before the push pull output. Check plate voltage on each 6C5 tube, pin #3. Should be positive.
I would normally use P-T156 which has a 1:3 gain but don't think it's needed in your radio. Impedance is important in transformers rather than DC resistance.
:Hello
:I have a Zenith 9-S-30 with an open primary in the input transformer. I do not know what the primary is supposed to read because it is not listed on the schematic. The secondary is still good and it is about 1200 ohms overall. I have put in a P-T124D from AES and the volume doesn't seem to be loud enough- primary totals around 500 ohms and secondary totals about 750 ohms. Does any one know which transformer would be a suitable and correct replacement from AES? Any help would be appreciated.
:Ryan
