Dave...
What happens when brightness is turned up? If the picture tube is good contrast is determined by Vidio amplifiers & video IF stages. Yes, video detector could be the problem. In older TV's it was a 6AL5, later ones germanium diode.
Sound is taken off after vidio IF stages in later TV's. Vidio IF's could still be weak and some sound would come through.
:Hello All,
: I have been working on this tv on and off for about a year now. I have tried many things but the sound stays strong and there is virtually zero contrast. The picture can just barely be seen. When I turn the contrast control down, the audio is affected too. There is less audio when the contrast control is turned down. I have taken out the tuner and examined everything thoroughly. I believe it is working fine.
: I have removed and examined the solder side of the pc board and found a few little things but nothing major. All paper and filter capacitors were replaced. I am wondering if this could be the video detector diode. That doesn't seem to make any sense.
: If I have sound, then why is the contrast so weak? It just doesn't make any sense. If I have sound, doesn't that mean that the video is fine? DC restoration is great I the brightness control works fine. There is a picture but it's so weak that it's unwatchable.
: Please help. I am about to give up on this set.
:Thanks,
:Dave...
Thanks very much,
Dave...
:Hi Dave
: What happens when brightness is turned up? If the picture tube is good contrast is determined by Vidio amplifiers & video IF stages. Yes, video detector could be the problem. In older TV's it was a 6AL5, later ones germanium diode.
: Sound is taken off after vidio IF stages in later TV's. Vidio IF's could still be weak and some sound would come through.
::Hello All,
:: I have been working on this tv on and off for about a year now. I have tried many things but the sound stays strong and there is virtually zero contrast. The picture can just barely be seen. When I turn the contrast control down, the audio is affected too. There is less audio when the contrast control is turned down. I have taken out the tuner and examined everything thoroughly. I believe it is working fine.
:: I have removed and examined the solder side of the pc board and found a few little things but nothing major. All paper and filter capacitors were replaced. I am wondering if this could be the video detector diode. That doesn't seem to make any sense.
:: If I have sound, then why is the contrast so weak? It just doesn't make any sense. If I have sound, doesn't that mean that the video is fine? DC restoration is great I the brightness control works fine. There is a picture but it's so weak that it's unwatchable.
:: Please help. I am about to give up on this set.
::Thanks,
::Dave...
That's good news. Since the screen does get bright your picture tube should be ok. I would work on replacing that diode and the checking 8AW8 circuit.
A 1N34 diode will work but the original was probably a diode rated as a video detector?
:Norm,
: When I turn up the brightness, the raster gets bright but the picture can no longer be seen. This is a Hot Chassis set with very few stages. It is an 8AW8 sync sepapator/video amp tube. The contrast and brightness are connected after the output of the video amp. The signal goes through a an r-l-c network and then through a capacitor to the cathode of the picture tube. There's not much there. There are no video stages past that, just the audio IF and amp.
: There is a diode diode detector. I'll use one of my 1N34As.
:So the video detector can be defective, yet sound can get through? Interesting. The sound is quite good. I will try replacing the diode and get back to you later. I want to be through with this set before the week-end is over.
:Thanks very much,
:Dave...
::Hi Dave
:: What happens when brightness is turned up? If the picture tube is good contrast is determined by Vidio amplifiers & video IF stages. Yes, video detector could be the problem. In older TV's it was a 6AL5, later ones germanium diode.
:: Sound is taken off after vidio IF stages in later TV's. Vidio IF's could still be weak and some sound would come through.
:::Hello All,
::: I have been working on this tv on and off for about a year now. I have tried many things but the sound stays strong and there is virtually zero contrast. The picture can just barely be seen. When I turn the contrast control down, the audio is affected too. There is less audio when the contrast control is turned down. I have taken out the tuner and examined everything thoroughly. I believe it is working fine.
::: I have removed and examined the solder side of the pc board and found a few little things but nothing major. All paper and filter capacitors were replaced. I am wondering if this could be the video detector diode. That doesn't seem to make any sense.
::: If I have sound, then why is the contrast so weak? It just doesn't make any sense. If I have sound, doesn't that mean that the video is fine? DC restoration is great I the brightness control works fine. There is a picture but it's so weak that it's unwatchable.
::: Please help. I am about to give up on this set.
:::Thanks,
:::Dave...
Thanks again,
Dave...
:Hi Dave
: That's good news. Since the screen does get bright your picture tube should be ok. I would work on replacing that diode and the checking 8AW8 circuit.
: A 1N34 diode will work but the original was probably a diode rated as a video detector?
::Norm,
:: When I turn up the brightness, the raster gets bright but the picture can no longer be seen. This is a Hot Chassis set with very few stages. It is an 8AW8 sync sepapator/video amp tube. The contrast and brightness are connected after the output of the video amp. The signal goes through a an r-l-c network and then through a capacitor to the cathode of the picture tube. There's not much there. There are no video stages past that, just the audio IF and amp.
:: There is a diode diode detector. I'll use one of my 1N34As.
::So the video detector can be defective, yet sound can get through? Interesting. The sound is quite good. I will try replacing the diode and get back to you later. I want to be through with this set before the week-end is over.
::Thanks very much,
::Dave...
:::Hi Dave
::: What happens when brightness is turned up? If the picture tube is good contrast is determined by Vidio amplifiers & video IF stages. Yes, video detector could be the problem. In older TV's it was a 6AL5, later ones germanium diode.
::: Sound is taken off after vidio IF stages in later TV's. Vidio IF's could still be weak and some sound would come through.
::::Hello All,
:::: I have been working on this tv on and off for about a year now. I have tried many things but the sound stays strong and there is virtually zero contrast. The picture can just barely be seen. When I turn the contrast control down, the audio is affected too. There is less audio when the contrast control is turned down. I have taken out the tuner and examined everything thoroughly. I believe it is working fine.
:::: I have removed and examined the solder side of the pc board and found a few little things but nothing major. All paper and filter capacitors were replaced. I am wondering if this could be the video detector diode. That doesn't seem to make any sense.
:::: If I have sound, then why is the contrast so weak? It just doesn't make any sense. If I have sound, doesn't that mean that the video is fine? DC restoration is great I the brightness control works fine. There is a picture but it's so weak that it's unwatchable.
:::: Please help. I am about to give up on this set.
::::Thanks,
::::Dave...
Thank very much for your help,
Dave...
:Norm,
: All I have are 1N34As on hand and I want to get done this weekend. If it works, that should be fine. There's so little in that 8AW8 video output circuit, I could replace it all, except for the coils. I don't see anything wrong with anything, however I have seen strange things before in other radios and TVs.
:Thanks again,
:Dave...
::Hi Dave
:: That's good news. Since the screen does get bright your picture tube should be ok. I would work on replacing that diode and the checking 8AW8 circuit.
:: A 1N34 diode will work but the original was probably a diode rated as a video detector?
:::Norm,
::: When I turn up the brightness, the raster gets bright but the picture can no longer be seen. This is a Hot Chassis set with very few stages. It is an 8AW8 sync sepapator/video amp tube. The contrast and brightness are connected after the output of the video amp. The signal goes through a an r-l-c network and then through a capacitor to the cathode of the picture tube. There's not much there. There are no video stages past that, just the audio IF and amp.
::: There is a diode diode detector. I'll use one of my 1N34As.
:::So the video detector can be defective, yet sound can get through? Interesting. The sound is quite good. I will try replacing the diode and get back to you later. I want to be through with this set before the week-end is over.
:::Thanks very much,
:::Dave...
::::Hi Dave
:::: What happens when brightness is turned up? If the picture tube is good contrast is determined by Vidio amplifiers & video IF stages. Yes, video detector could be the problem. In older TV's it was a 6AL5, later ones germanium diode.
:::: Sound is taken off after vidio IF stages in later TV's. Vidio IF's could still be weak and some sound would come through.
::::Norm
:::::Hello All,
::::: I have been working on this tv on and off for about a year now. I have tried many things but the sound stays strong and there is virtually zero contrast. The picture can just barely be seen. When I turn the contrast control down, the audio is affected too. There is less audio when the contrast control is turned down. I have taken out the tuner and examined everything thoroughly. I believe it is working fine.
::::: I have removed and examined the solder side of the pc board and found a few little things but nothing major. All paper and filter capacitors were replaced. I am wondering if this could be the video detector diode. That doesn't seem to make any sense.
::::: If I have sound, then why is the contrast so weak? It just doesn't make any sense. If I have sound, doesn't that mean that the video is fine? DC restoration is great I the brightness control works fine. There is a picture but it's so weak that it's unwatchable.
::::: Please help. I am about to give up on this set.
:::::Thanks,
:::::Dave...
Dave...
:Norm,
: I found the problem in between the 3rd IF amp and video output tube. I now have a very strong picture.
:Thank very much for your help,
:Dave...
::Norm,
:: All I have are 1N34As on hand and I want to get done this weekend. If it works, that should be fine. There's so little in that 8AW8 video output circuit, I could replace it all, except for the coils. I don't see anything wrong with anything, however I have seen strange things before in other radios and TVs.
::Thanks again,
::Dave...
:::Hi Dave
::: That's good news. Since the screen does get bright your picture tube should be ok. I would work on replacing that diode and the checking 8AW8 circuit.
::: A 1N34 diode will work but the original was probably a diode rated as a video detector?
::::Norm,
:::: When I turn up the brightness, the raster gets bright but the picture can no longer be seen. This is a Hot Chassis set with very few stages. It is an 8AW8 sync sepapator/video amp tube. The contrast and brightness are connected after the output of the video amp. The signal goes through a an r-l-c network and then through a capacitor to the cathode of the picture tube. There's not much there. There are no video stages past that, just the audio IF and amp.
:::: There is a diode diode detector. I'll use one of my 1N34As.
::::So the video detector can be defective, yet sound can get through? Interesting. The sound is quite good. I will try replacing the diode and get back to you later. I want to be through with this set before the week-end is over.
::::Thanks very much,
::::Dave...
:::::Hi Dave
::::: What happens when brightness is turned up? If the picture tube is good contrast is determined by Vidio amplifiers & video IF stages. Yes, video detector could be the problem. In older TV's it was a 6AL5, later ones germanium diode.
::::: Sound is taken off after vidio IF stages in later TV's. Vidio IF's could still be weak and some sound would come through.
:::::Norm
::::::Hello All,
:::::: I have been working on this tv on and off for about a year now. I have tried many things but the sound stays strong and there is virtually zero contrast. The picture can just barely be seen. When I turn the contrast control down, the audio is affected too. There is less audio when the contrast control is turned down. I have taken out the tuner and examined everything thoroughly. I believe it is working fine.
:::::: I have removed and examined the solder side of the pc board and found a few little things but nothing major. All paper and filter capacitors were replaced. I am wondering if this could be the video detector diode. That doesn't seem to make any sense.
:::::: If I have sound, then why is the contrast so weak? It just doesn't make any sense. If I have sound, doesn't that mean that the video is fine? DC restoration is great I the brightness control works fine. There is a picture but it's so weak that it's unwatchable.
:::::: Please help. I am about to give up on this set.
::::::Thanks,
::::::Dave...
