What approach should I take to supplying power - use large programmable units, build a transformer from 110 AC, what is your recomendation.
What should I use for a speaker/headset?
Troy
Best to build a power supply. Your radio uses 01A tubes. Each takes 5 volts @ .25 amps on the filament. "B" battery voltage should be 90 with lower voltage for the detector.
Use a high impedance speaker. A modern speaker will work but will require an output transformer.
Schematic for your radio can be found here:
http://www.nostalgiaair.org/PagesByModel/885/M0039885.pdf
:I picked up a set of NR-5 radios. They appear to be from a storage cener and sat on a shelf for 85 years. Everything looks good. I would like to know.
:What approach should I take to supplying power - use large programmable units, build a transformer from 110 AC, what is your recomendation.
:What should I use for a speaker/headset?
:Thanks,
:Troy
