Lafayette Explor-Air
10/7/2005 10:24:14 AMLou
Sirs:
Does anyone have a manual/schematic for a Lafayette Explor-Air?
This was a three -tube regen. SW set.
10/7/2005 2:51:26 PMDave McLeod
:Sirs:
:Does anyone have a manual/schematic for a Lafayette Explor-Air?
:This was a three -tube regen. SW set.
Hello Lou:
I do have an assembly manual (two actually - the original Lafayette manual was incomplete (that is a story in itself!). Unfortunately, it is in the black hole of my basement which I am attempting to clean up and everything is toppsy-turrvy. It may take me a day or so but I'll rummage around and attempt to find it for you.
10/7/2005 4:42:04 PMDave McLeod
::Sirs:
::Does anyone have a manual/schematic for a Lafayette Explor-Air?
::This was a three -tube regen. SW set.
:Hello Lou:
:I do have an assembly manual (two actually - the original Lafayette manual was incomplete (that is a story in itself!). Unfortunately, it is in the black hole of my basement which I am attempting to clean up and everything is toppsy-turrvy. It may take me a day or so but I'll rummage around and attempt to find it for you.
Hello again Lou:
I have located the schematic for the unit... could you provide an email address so I may forward please?
10/7/2005 5:33:57 PMLou
:::Sirs:
:::Does anyone have a manual/schematic for a Lafayette Explor-Air?
:::This was a three -tube regen. SW set.
::Hello Lou:
::I do have an assembly manual (two actually - the original Lafayette manual was incomplete (that is a story in itself!). Unfortunately, it is in the black hole of my basement which I am attempting to clean up and everything is toppsy-turrvy. It may take me a day or so but I'll rummage around and attempt to find it for you.
:Hello again Lou:
:I have located the schematic for the unit... could you provide an email address so I may forward please?
:Thanks
Please E-mail the schematic to : louis226@juno.com
FYI: I found this set in Antique Radio Classified
It currently works. I had one when I was 12 years old. I am now 47. Quite a span of time, and a very nostalgic radio for me.
Lou
10/8/2005 3:56:41 PMRadiodoc
::::Sirs:
::::Does anyone have a manual/schematic for a Lafayette Explor-Air?
::::This was a three -tube regen. SW set.
:::Hello Lou:
:::I do have an assembly manual (two actually - the original Lafayette manual was incomplete (that is a story in itself!). Unfortunately, it is in the black hole of my basement which I am attempting to clean up and everything is toppsy-turrvy. It may take me a day or so but I'll rummage around and attempt to find it for you.
::Hello again Lou:
::I have located the schematic for the unit... could you provide an email address so I may forward please?
::Thanks
:Thanks
:Please E-mail the schematic to : louis226@juno.com
:FYI: I found this set in Antique Radio Classified
:It currently works. I had one when I was 12 years old. I am now 47. Quite a span of time, and a very nostalgic radio for me.
:Lou
Lou,
There is an assembly manual with schematic for a Lafayette Explor-Air (KT135) 3-tube regen radio at http://bama.sbc.edu/lafayett.htm. The filename is explor.djvu. Perhaps this is your radio.
11/13/2005 9:46:19 PMEric Hayes
:::Sirs:
::Hello Lou:
:Hello again Lou:
:Thanks
11/13/2005 9:50:47 PMEric Hayes
:::Sirs:
:::Hi Dave,
:::I, too, am in need of an Explor-air schmatic so I can figure why it's going into regeneration so quickly. Appears to be well built, but still a kit...
Many thanks,
Eric
::Hello Lou:
:Hello again Lou:
:Thanks
11/17/2005 11:40:07 PMDave
Hello Eric:
Sorry for the late response but I've been having computer problems for the past few days and have just got this thing running half-way decently.
I can scan the schematic and forward it to you via separate emails if you still require it.
Regards,
::::Sirs:
::::Hi Dave,
::::I, too, am in need of an Explor-air schmatic so I can figure why it's going into regeneration so quickly. Appears to be well built, but still a kit...
:Many thanks,
:Eric
:::Hello Lou:
::Hello again Lou:
::Thanks
