crosley 10-127 volume switch
10/3/2005 8:32:17 PMhhefner
i have a crosley model 10-127 am&fm set that needs a volume on off switch it is 1mohms with tap at 300kohms
the shaft just keeps turning no stopping point anyone know where i can buy one of these?
any help greatly appreciated.
thanks
10/4/2005 3:11:24 PMThomas Dermody
If the control works fine but keeps turning, then you can try opening it up and seeing if the stop is bent or broken. Try repairing it. If a tap broke off, a new one can be made from a small piece of metal. This can be soldered in place.
10/8/2005 10:04:18 AMPhil N.
:i have a crosley model 10-127 am&fm set that needs a volume on off switch it is 1mohms with tap at 300kohms
:the shaft just keeps turning no stopping point anyone know where i can buy one of these?
:any help greatly appreciated.
:thanks
From an old Radio Shack catalog I found a SPST pot switch Radio Shack part number 271-1740 for $1.49. If they still sell it it would be in their set of drawers probably under potentiometers. Or you can ask them to order it.
Phil N.
