Yes, the gold band resistors are a tighter tolerance meaning they are closer to the specified resistance and are suitable replacements. As long as you use a replacement resistor of the same resistance value (ohms) and the same or greater power rating (wattage). Also note that the 5% resistors are more expensive than ones of looser tolerance.
http://www.nostalgiaair.org/Resources/581/M0006581.htm
this is a first time radio for me to repair so im not to savy on reading schematics. help would be appreciated. some of the resistors are decayed so i figured i may as well replace them. ive all ready tested the capacitors, and will get replacements for the bad ones this weekend.
If your old resistors are the same physical size as a new 1/2 W, chances are they are indeed 1/2 W. In all the tube radios I've repaired, I've never found any resistors with a power rating less than 1/2 Watt.
Mark
:ok, so i have resistors that match the same color sequences for the resistors in my radio. now how do i determine the wattage? i threw the package away for the resistors long ago. i bought an assortment from radio shack. the radio i have is a motorola 401 whose schematic is located at this link:
:http://www.nostalgiaair.org/Resources/581/M0006581.htm
:this is a first time radio for me to repair so im not to savy on reading schematics. help would be appreciated. some of the resistors are decayed so i figured i may as well replace them. ive all ready tested the capacitors, and will get replacements for the bad ones this weekend.
russell
:Hi Russell,
:The wattage rating for a resistor is determined by the physical size of the resistor. Look at the package of the resistor assortment you bought from Radio Shack. It should tell you if the resistors are 1/4 Watt or 1/2 Watt.
:If your old resistors are the same physical size as a new 1/2 W, chances are they are indeed 1/2 W. In all the tube radios I've repaired, I've never found any resistors with a power rating less than 1/2 Watt.
:Mark
:well the resistors i have are tiny, like the size of a big grain of rice. the resistors on the radio vary in in size from rice size all the way up to "crayon broken in half size" any suggestions?
:russell
::Hi Russell,
::The wattage rating for a resistor is determined by the physical size of the resistor. Look at the package of the resistor assortment you bought from Radio Shack. It should tell you if the resistors are 1/4 Watt or 1/2 Watt.
::If your old resistors are the same physical size as a new 1/2 W, chances are they are indeed 1/2 W. In all the tube radios I've repaired, I've never found any resistors with a power rating less than 1/2 Watt.
::Mark
