More elaborate versions may include strong RF amplifiers after the oscillator, which will increase signal coverage (which may or may not be illegal in your area, but as long as you don't interfere with anyone and cause complaints, you won't likely get in trouble if you only broadcast on occasion).
Milton
:I can get you some schematics, and you can also buy a kit from www.tubesandmore.com. All you really need to do is build an oscillator circuit like that found in most five tube AC-DC radios (or AC radios, but many circuit variations exist here). Use a common oscillator tube like 12SA7 or 6A7 or 6A8. You can use a combination of two tubes by using a triode for an oscillator and a pentode as a converter. You can either use an air tuned coil for the oscillator, with an accompanying condenser for finding the frequency you wish to use, or you can use a permeably tuned coil, which can simply be tuned with the slug inside the coil.
:More elaborate versions may include strong RF amplifiers after the oscillator, which will increase signal coverage (which may or may not be illegal in your area, but as long as you don't interfere with anyone and cause complaints, you won't likely get in trouble if you only broadcast on occasion).
:Thomas
JK posted his question on another forum. He got some good leads for schematics.
http://antiqueradios.com/forums/Forum13/HTML/008098.html
:I would be interested in get some schematics too, if I understand what JK wants is a small local transmitter for AM broadcast but not as little as the unit that sells Tubesandmore which is for indoor use mainly.
:I guess he wants to transmit signals more far than the walls of his house, Ilegal or not.
:Milton
::I can get you some schematics, and you can also buy a kit from www.tubesandmore.com. All you really need to do is build an oscillator circuit like that found in most five tube AC-DC radios (or AC radios, but many circuit variations exist here). Use a common oscillator tube like 12SA7 or 6A7 or 6A8. You can use a combination of two tubes by using a triode for an oscillator and a pentode as a converter. You can either use an air tuned coil for the oscillator, with an accompanying condenser for finding the frequency you wish to use, or you can use a permeably tuned coil, which can simply be tuned with the slug inside the coil.
::More elaborate versions may include strong RF amplifiers after the oscillator, which will increase signal coverage (which may or may not be illegal in your area, but as long as you don't interfere with anyone and cause complaints, you won't likely get in trouble if you only broadcast on occasion).
::Thomas
http://www.oldradioz.com/schematics/AM_Transmitter_6BM8.pdf
Thanks for all the help. JK
Increasing supply voltage will give more output power. Should be able to get 5 watts with a 12V6 & 300 volts B+.
:Here is the Schematic of the 6BM8, I thought about using a 6j5gt, and a 12V6GT instaed of the 6BM8. What will be performance changes other than output, i should have more output with the 12v6gt right? sound should still be pretty good? I might build a second one using a 6U8A for comparison.
:http://www.oldradioz.com/schematics/AM_Transmitter_6BM8.pdf
:Thanks for all the help. JK
:Does anyone know where i can find a schematic to biuld a transmitter for standard broadcast. There isn't much on AM where I live. Thanks,
:You can use your signal generator as a transmitter. It must have a modulation input (audio input). I have done it with mine. My generator isn't that strong, but it does the trick. If you want, just connect the generator directly to the antenna of your radio. This is somewhat simpler than going inside of the radio and connecting your CD player to the amplifier.
:Thomas
This circuit uses a 12SA7, which was the tube mentioned in a recent post:
http://www.nostalgiaair.org/Forums/Messages/695/M0032695.htm
This project used a disguised 12SA7 and several vintage parts to build a transmitter to look like a home brew set of about 1924.
Yes, at least Frys used to sell a FM stereo kit for 40 dollars or so. I built one, and used it to listen to my CD changer in the house while I garden with a walkman, it works for about two houses, then fades out.
Amanda Sharrai
734-260-0517 (cell)
I made a few http://home.comcast.net/~suptjud/AMtransmitter.htm
