Part: BY500-800
Description: 800 V, 5 A, Soft Recovery Fast Switching Plastic Rectifier
How does it compare with the 1N4007 as a replacement for a selenium rectifier?
Terry
A 1N4007 is rated 100 v @ 1 amp.
Selenium rectifiers are usually rated to 380 PIV at currents from 50 ma to 750 ma for some TV's.
Either type diode will be ok to replace a selenium rectifier. You should add some series resistance to reduce surge current and drop a few volts. A silicon diode has a voltage drop around .7 volts. Selenium rectifier 7-9 volts.
:Is anyone familiar with this diode:
:Part: BY500-800
:Description: 800 V, 5 A, Soft Recovery Fast Switching Plastic Rectifier
:How does it compare with the 1N4007 as a replacement for a selenium rectifier?
:Terry
:Hi Terry
: A 1N4007 is rated 100 v @ 1 amp.
: Selenium rectifiers are usually rated to 380 PIV at currents from 50 ma to 750 ma for some TV's.
: Either type diode will be ok to replace a selenium rectifier. You should add some series resistance to reduce surge current and drop a few volts. A silicon diode has a voltage drop around .7 volts. Selenium rectifier 7-9 volts.
::Is anyone familiar with this diode:
::Part: BY500-800
::Description: 800 V, 5 A, Soft Recovery Fast Switching Plastic Rectifier
::How does it compare with the 1N4007 as a replacement for a selenium rectifier?
::Terry
Terry
As Norm says, the BY part should work fine, but it is a needless expense. The BY is a fast recovery device intended for switch-mode power supplies operating above 20 KHz. If you have 1N4007s... use 'em. Don't pay 5x more for something you don't need. Rich
