Here is information on your radio:
http://www.nostalgiaair.org/PagesByModel/934/M0017934.pdf
Crosley Musicone speaker will work. Be careful not to touch speaker connections while power is on. Plate B+ from your 71A's are on these connections.
:This weekend I found a Silvertone Model J (R4433). It has 4-26, 1-27, 2-71a and 80 all in a metal cabinet. The radio will require a lot of clean up and work but I also got a Crosley "D" Musicone speaker. Anyone know if this speaker will work with this radio?
:Thanks,
:Hi Darrel
: Here is information on your radio:
:http://www.nostalgiaair.org/PagesByModel/934/M0017934.pdf
: Crosley Musicone speaker will work. Be careful not to touch speaker connections while power is on. Plate B+ from your 71A's are on these connections.
::This weekend I found a Silvertone Model J (R4433). It has 4-26, 1-27, 2-71a and 80 all in a metal cabinet. The radio will require a lot of clean up and work but I also got a Crosley "D" Musicone speaker. Anyone know if this speaker will work with this radio?
::Thanks,
You can use 4 mf caps. I would probably use 10 mf @ 450 volt caps. Voltage may be a little higher but hum reduced. In the late 1920's large capacitors were expensive.
Be sure the power transformer doesn't have a problem. You can check it by removing your 80 tube and apply power. Tubes should light but the transformer should not get hot.
:Thanks Norm, I'll watch out for that B+. It looks like first I have a lot of tar to clean up and a lot of transformers to check out before I apply power. Also, can I use 4 uf electrolytic capacitors for the 3uf? it looks like there are a lot of 1, 2 and 3uf capacitors in a tar filled can.
::Hi Darrel
:: Here is information on your radio:
::http://www.nostalgiaair.org/PagesByModel/934/M0017934.pdf
:: Crosley Musicone speaker will work. Be careful not to touch speaker connections while power is on. Plate B+ from your 71A's are on these connections.
:::This weekend I found a Silvertone Model J (R4433). It has 4-26, 1-27, 2-71a and 80 all in a metal cabinet. The radio will require a lot of clean up and work but I also got a Crosley "D" Musicone speaker. Anyone know if this speaker will work with this radio?
:::Thanks,
:Hi Darrel
: You can use 4 mf caps. I would probably use 10 mf @ 450 volt caps. Voltage may be a little higher but hum reduced. In the late 1920's large capacitors were expensive.
: Be sure the power transformer doesn't have a problem. You can check it by removing your 80 tube and apply power. Tubes should light but the transformer should not get hot.
::Thanks Norm, I'll watch out for that B+. It looks like first I have a lot of tar to clean up and a lot of transformers to check out before I apply power. Also, can I use 4 uf electrolytic capacitors for the 3uf? it looks like there are a lot of 1, 2 and 3uf capacitors in a tar filled can.
:::Hi Darrel
::: Here is information on your radio:
:::http://www.nostalgiaair.org/PagesByModel/934/M0017934.pdf
::: Crosley Musicone speaker will work. Be careful not to touch speaker connections while power is on. Plate B+ from your 71A's are on these connections.
::::This weekend I found a Silvertone Model J (R4433). It has 4-26, 1-27, 2-71a and 80 all in a metal cabinet. The radio will require a lot of clean up and work but I also got a Crosley "D" Musicone speaker. Anyone know if this speaker will work with this radio?
::::Thanks,
