Steve
stvoigt@juno.com
Steve
:What can happen when you use excessive lubricant on a volume control is that carbon granules from the control get in the lubricant and form unwanted resistance paths. It is best to clean all lubricant from the control and from the circuit board using a rag dipped in alcohol or mineral spirits (do not use acetone or you will ruin plastic parts, etc.). Disassemble the volume control and wash it thoroughly in hot water and soap. Coat the resistance element with a very thin layer of dielectric grease (found at your automotive parts store). Place this grease on the shaft bearings as well. Reassemble and enjoy.
:Thomas
