B&K 700 Tube Tester
8/24/2005 10:22:18 AMRick
I'm looking for the tube settings for the 6B7 tube. I would think that the setting would be the same for some of the other B&K testers. Thanks..
8/25/2005 11:10:43 AMDick
Rick: My RCA tube manual says that the 6B7 and 6B8 have the same characteristics, but the pin layout is different. You may be able to alter your tester settings for the 6B7 pin configuration.
8/25/2005 11:56:41 AMRick
:Rick: My RCA tube manual says that the 6B7 and 6B8 have the same characteristics, but the pin layout is different. You may be able to alter your tester settings for the 6B7 pin configuration.
Thanks, but I thought about that already and did not seem to work for me or I have a bad tube.
