A note about 78s vs. microgroove records. 78 rpm records have approximately (standard) a 3 mil groove. Long playing records (microgroove) have a 1 mil groove. Most replacement needles for flip cartridges do not come fitted with 3 mil needles with the stupid assumption that noone plays 78s anymore. Unless your 78 needle is fitted with a properly ground 3 mil needle, your 78s will hiss and sound poor. If you push the needle to one side of the groove and then the hiss goes away somewhat, then you know you have the wrong sized needle. A proper needle will fit the groove properly and won't bounce around the bottom. Properly played 78s in good condition are a treat to listen to. They are velvety smooth and like a dream (especially when the Modernaires or Helen Forrest are singing).
