AZ31 Rectifier
8/13/2005 7:16:59 PMMark
Does anyone have information on this Valve/Tube? There is no reference in the book for my tube tester.
8/14/2005 10:47:09 AMNorm Leal
Hi Mark
AZ31 is not used in the US. I did find this tube listed in a manual from Australia.
AZ31 is a full wave rectifier. Filament rated 4 volts @ 1.1 amps. Can supply 100 ma if used with 300 volts input. Derate current to 60 ma with 500 volts. Filament pins 2 and 8. Plates pins 4 and 6.
Might get away with using a 5W4? Pins are the same but filament is rated 5 volts @ 1.5 amps. A high emission tube should work.
:Does anyone have information on this Valve/Tube? There is no reference in the book for my tube tester.
8/15/2005 8:26:37 AMJose A. Gonzalez
Hi Mark.
In this link you have the data sheet.
http://www.mif.pg.gda.pl/homepages/frank/sheets/030/a/AZ31.pdf
Jose A. Gonzalez
:Hi Mark
: AZ31 is not used in the US. I did find this tube listed in a manual from Australia.
: AZ31 is a full wave rectifier. Filament rated 4 volts @ 1.1 amps. Can supply 100 ma if used with 300 volts input. Derate current to 60 ma with 500 volts. Filament pins 2 and 8. Plates pins 4 and 6.
: Might get away with using a 5W4? Pins are the same but filament is rated 5 volts @ 1.5 amps. A high emission tube should work.
::Does anyone have information on this Valve/Tube? There is no reference in the book for my tube tester.
