Thx,
Dan
If you don't know the exact values use 2.2 meg for grid leak and .001 mf for cap after the detector plate.
Older radio used grid leaks to 5 meg or more. Most of these are open or have gone even higher. A resistor of 2 meg was the most popular.
After the detector there are different filter networks. Some with two caps and a choke between them. Use .001 mf for this/these caps. If you use too large a value high frequency audio response will be reduced.
:What should the values of the grid leak resistor and cap be for a Radiola X?
:What value should the bypass cap after the detector plate coil be?
:Thx,
:Dan
