I'm a little confused from your question, though. Is it an IF xfmr or the oscillator coil that was open?
A bad IF xfmr shouldn't keep the oscillator from working, should it? And a bad oscillator coil I don't could be bypassed with an RC ckt like can be tried for an IF xfmr.
hi been there done that i finally bought a nos coil from playthings of the the past and the set works good now i think i could have rewound the original coil but in mine it was fried and fell into pieces and there was no way to count the winds. this set is kind of shakey anyhow as the vol. works by limiting ant. signal.butch
This is the web address of Playthings of the Past:
http://www.oldradioparts.com
Dennis Wess
i think it has to be very close to work i tried some substitutions on mine they work somewhat but not really very good but if you can count your coils winds and get them in the same positions as original i see no reason why you can't rewind one unless the radio gods are out to get you.butch
Jon, It is me again. If you haven't-go to the resources part of this sight and download the manual for the model 15. This is a screen grid receiver and they are very difficult to align because of the low IF freq being 175 kc, they have imense image problems. Grunow even cautions one about not aligning the if cans. Also the cathode bias is controlled by the volume control. Check the resistance of the pot and the series resistor that comes from the volume control. Also this receiver has an ascillator tracking condensor. You need to rock the tuning cap to get it set up correctly on the low end of the band. Again the impedence of your rewinding effort is very important as the method in which you align this set. Good luck again, Boyd
