For the "A", filament, supply use a small 6.3 volt filament transformer. Rectify, filter and use a LM317 to regulate voltage.
For the "B" voltages use an isolation transformer. Use a diode, filters and resistors to drop voltage. Detector voltage should be around 20 but second stage can be much higher. With around 90 volts a Radiola lll will operate a speaker.
Check out transformer G13510 at www.goldmine-elec.com . Only $2.49 and it has two primary windings. (One can be used as primary & other isolation secondary.) Also has 2 - 6.3 volt windings. You can use 1 for "A", filament & the second can be for "C" voltage.
I can send basic information if you list your email address.
Check to be sure the audio interstage transformer isn't open.
:i would like to make a power supply for a Radiola 111. It will only be used for this radio so I only need 1.5v (A), 20v and 40v (B) and 1.5v (C). I have rebased 1A5 tubes to replace the WD11 tubes.I have many transformers that I can use but the output is like 270volts c.t. or higher, 6volts and 5volts. What is the best way to drop these outputs to the needed voltage? should I use large wattage resistors accross the rectified outputs or zener diodes? If I should use the diodes how would I do it? What about bypass caps to keep hum and buzz out? Where should I install them?
:Thanks for the help, Tom
Norm,Thanks for the help, My e-mail is tkelly1@wsscwater.com I will look into the transformer you talked about, I would also like some more info on bypass caps to keep the noise down. also can I get that LM317 regulator from Radio Shack?
Thanks again, Tom
Information sent.
:::Hi Tom
::: For the "A", filament, supply use a small 6.3 volt filament transformer. Rectify, filter and use a LM317 to regulate voltage.
::: For the "B" voltages use an isolation transformer. Use a diode, filters and resistors to drop voltage. Detector voltage should be around 20 but second stage can be much higher. With around 90 volts a Radiola lll will operate a speaker.
::: Check out transformer G13510 at www.goldmine-elec.com . Only $2.49 and it has two primary windings. (One can be used as primary & other isolation secondary.) Also has 2 - 6.3 volt windings. You can use 1 for "A", filament & the second can be for "C" voltage.
::: I can send basic information if you list your email address.
::: Check to be sure the audio interstage transformer isn't open.
::::i would like to make a power supply for a Radiola 111. It will only be used for this radio so I only need 1.5v (A), 20v and 40v (B) and 1.5v (C). I have rebased 1A5 tubes to replace the WD11 tubes.I have many transformers that I can use but the output is like 270volts c.t. or higher, 6volts and 5volts. What is the best way to drop these outputs to the needed voltage? should I use large wattage resistors accross the rectified outputs or zener diodes? If I should use the diodes how would I do it? What about bypass caps to keep hum and buzz out? Where should I install them?
::::Thanks for the help, Tom
:Norm,Thanks for the help, My e-mail is tkelly1@wsscwater.com I will look into the transformer you talked about, I would also like some more info on bypass caps to keep the noise down. also can I get that LM317 regulator from Radio Shack?
:Thanks again, Tom
:Hi Tom
: Information sent.
::::Hi Tom
:::: For the "A", filament, supply use a small 6.3 volt filament transformer. Rectify, filter and use a LM317 to regulate voltage.
:::: For the "B" voltages use an isolation transformer. Use a diode, filters and resistors to drop voltage. Detector voltage should be around 20 but second stage can be much higher. With around 90 volts a Radiola lll will operate a speaker.
:::: Check out transformer G13510 at www.goldmine-elec.com . Only $2.49 and it has two primary windings. (One can be used as primary & other isolation secondary.) Also has 2 - 6.3 volt windings. You can use 1 for "A", filament & the second can be for "C" voltage.
:::: I can send basic information if you list your email address.
:::: Check to be sure the audio interstage transformer isn't open.
::::Norm
:::::i would like to make a power supply for a Radiola 111. It will only be used for this radio so I only need 1.5v (A), 20v and 40v (B) and 1.5v (C). I have rebased 1A5 tubes to replace the WD11 tubes.I have many transformers that I can use but the output is like 270volts c.t. or higher, 6volts and 5volts. What is the best way to drop these outputs to the needed voltage? should I use large wattage resistors accross the rectified outputs or zener diodes? If I should use the diodes how would I do it? What about bypass caps to keep hum and buzz out? Where should I install them?
:::::Thanks for the help, Tom
::Norm,Thanks for the help, My e-mail is tkelly1@wsscwater.com I will look into the transformer you talked about, I would also like some more info on bypass caps to keep the noise down. also can I get that LM317 regulator from Radio Shack?
::Thanks again, Tom
:::Hi Tom
:Thanks again, Tom
