64BR-1503B
I can't seem to find a schematic for that exact model, but the 1503C appears to match although there is no info about the coil other than how it connects (not even an ohms rating on each of the two coils). I seem to recall reading that the differecne between the 1503B and 1503C was something about the case they were in.
I will see what I can figure out.
If the original coil had two windings, the one that matters connects to the tuning capacitor. A winding for connecting an external antenna is pretty uncritical.
If you have access to instruments for measuring inductance, you might connect an adjustable loopstick antenna coil, adjust it to allow alignment of the radio, then measure the inductance to find the value that you need. You can then design a coil to get this inductance.
It should be possible to develop a coil by trial and error. If the set can be aligned, the coil is close enough. ( The part of alignment of concern here is the RF and oscillator alignment, not the IF alignment! )
Note that to tune the entire AM broadcast band, the coil will need to be wound to have relatively low self capacitance. A jumble-wound coil on a stick may not work.
The radio may still work well enough even if the antenna coil isn't correct. You might try a coil off a junk set, or winding something yourself and seeing if it works.
Ted
