Late 20's Airline radio
7/4/2005 4:01:32 PMBill Cahill
I have a late 20's Airline radio missing the model no. that I need the schematic for. It is a 9 tube set using 1-80, 2-45's, 1-24, and 5-26's. It is an upright radio on tall legs. Matched walnut with sliding doors in front. A.C. operated. 10" speaker below. All tubes in line accross back. Power transformer, filter choke, and filter capacitors are above the skinny, black painted chassis. 4 Gang tuner. Also has capability of connecting a magnetic phonograph to it. This is, however, a straight radio, only. Need picture of front, knobs, door knobs, schematic, tunning info., parts list, pictures, chassis anchors, and top chassis shield. Someone was going to turn this beuty into a liquer cabinet. I got a c part working on it. Had a bad switch. All transformers good. Please help me save this set. Contact: Bill Cahill fanaticbill@verizon.net
7/5/2005 8:49:49 AMNorm Leal
Hi Bill
See if model #2655 matches. It uses the same tubes all in line.
http://www.nostalgiaair.org/PagesByModel/522/M0043522.pdf
:I have a late 20's Airline radio missing the model no. that I need the schematic for. It is a 9 tube set using 1-80, 2-45's, 1-24, and 5-26's. It is an upright radio on tall legs. Matched walnut with sliding doors in front. A.C. operated. 10" speaker below. All tubes in line accross back. Power transformer, filter choke, and filter capacitors are above the skinny, black painted chassis. 4 Gang tuner. Also has capability of connecting a magnetic phonograph to it. This is, however, a straight radio, only. Need picture of front, knobs, door knobs, schematic, tunning info., parts list, pictures, chassis anchors, and top chassis shield. Someone was going to turn this beuty into a liquer cabinet. I got a c part working on it. Had a bad switch. All transformers good. Please help me save this set. Contact: Bill Cahill fanaticbill@verizon.net
