SIC TD55 and 6550 Tubes
7/3/2005 8:48:31 AMBrewer
Can the Superior Instruments Model - TD-55 Tube Tester test 6550 tubes?
7/6/2005 2:03:39 PMGeorge
:Can the Superior Instruments Model - TD-55 Tube Tester test 6550 tubes?
Check to see if you have data to test a KT88. Should be about the same.
7/8/2005 11:21:20 AMNorm Leal
Hi
If you don't have KT88 try 6L6. KT88 is similar to 6550 but from Europe. The 6550 is a higher power tube than 6L6 but same pinout.
::Can the Superior Instruments Model - TD-55 Tube Tester test 6550 tubes?
:Check to see if you have data to test a KT88. Should be about the same.
