I am repairing a Legend guitar tube amplifier for a friend and would like some advice. This is a Legend Model G1250 SC amplifier with 3 12AX7A tubes, and diodes and transistors. My friend had it previously evaluated by a repair shop and was told that the power transformer was 'bad.' There are 2 power transformers and the higher voltage rectified one is only putting out 80 volts DC to the plates of the tubes. But, I don't have a schematic to tell me the proper voltage to apply to these tubes - it can be 200 V or 280 V DC. So, I don't know what rating transformer to recommend that he purchase; and, I don't know if there is a voltage doubling DC power supply circuit that has a bad diode that would be simplier to fix.
Is anyone familiar with similar amplifier designs, or does anyone have a schematic I can borrow?
Thanks, Steve
I don't have your schematic but there is an easy way to check the power transformers. Disconnect the rectifier diodes and turn on the power. If the transformers put out any voltage and do not heat, they are good. A bad transformer will have a shorted winding and overheat is a few minutes.
If your transformer is putting out 80 volts and not overheating, it is good.
: Happy new year all,
: I am repairing a Legend guitar tube amplifier for a friend and would like some advice. This is a Legend Model G1250 SC amplifier with 3 12AX7A tubes, and diodes and transistors. My friend had it previously evaluated by a repair shop and was told that the power transformer was 'bad.' There are 2 power transformers and the higher voltage rectified one is only putting out 80 volts DC to the plates of the tubes. But, I don't have a schematic to tell me the proper voltage to apply to these tubes - it can be 200 V or 280 V DC. So, I don't know what rating transformer to recommend that he purchase; and, I don't know if there is a voltage doubling DC power supply circuit that has a bad diode that would be simplier to fix.
: Is anyone familiar with similar amplifier designs, or does anyone have a schematic I can borrow?
: Thanks, Steve
A couple of notes on the power transformer.
1. Check the primary (without power) with an
ohm-meter. Check across the line (be sure
the fuse is not blown) for about 1-2 ohms
and from either side of the line to the
chassis. That better be read an open circuit.
If not, you've got a primary leakage problem.
2. As Norm mentioned, disconnect ALL secondary
leads of your transformer (a short on one
secondary winding will load down the entire
transformer). Then check with an ohm-meter
for a short from any secondary wire to chassis.
3. Apply AC power to the transformer primary
and turn ON the power switch with all
secondaries wires OPEN. (all disconnected from
anything) and see (as Norn noted) if the
transformer overheats. You'll know in about 2 mins.
4. Remember the voltage across the secondary
of a transformer is always AC. You ought
to read anywhere from 80-120 VAC. May be
higher.
Please report your progress and good luck.
Phil Sussman
Clayton, Ohio
PS. Bubbling, gurgling, smoke, bad smells,
heating, or dripping wax from your
transformer are not good signs.
: Hi Steve
: I don't have your schematic but there is an easy way to check the power transformers. Disconnect the rectifier diodes and turn on the power. If the transformers put out any voltage and do not heat, they are good. A bad transformer will have a shorted winding and overheat is a few minutes.
: If your transformer is putting out 80 volts and not overheating, it is good.
: Norm
: : Happy new year all,
: : I am repairing a Legend guitar tube amplifier for a friend and would like some advice. This is a Legend Model G1250 SC amplifier with 3 12AX7A tubes, and diodes and transistors. My friend had it previously evaluated by a repair shop and was told that the power transformer was 'bad.' There are 2 power transformers and the higher voltage rectified one is only putting out 80 volts DC to the plates of the tubes. But, I don't have a schematic to tell me the proper voltage to apply to these tubes - it can be 200 V or 280 V DC. So, I don't know what rating transformer to recommend that he purchase; and, I don't know if there is a voltage doubling DC power supply circuit that has a bad diode that would be simplier to fix.
: : Is anyone familiar with similar amplifier designs, or does anyone have a schematic I can borrow?
: : Thanks, Steve
Any Suggestions?
Geoff
: Hey Steve,
: A couple of notes on the power transformer.
: 1. Check the primary (without power) with an
: ohm-meter. Check across the line (be sure
: the fuse is not blown) for about 1-2 ohms
: and from either side of the line to the
: chassis. That better be read an open circuit.
: If not, you've got a primary leakage problem.
: 2. As Norm mentioned, disconnect ALL secondary
: leads of your transformer (a short on one
: secondary winding will load down the entire
: transformer). Then check with an ohm-meter
: for a short from any secondary wire to chassis.
: 3. Apply AC power to the transformer primary
: and turn ON the power switch with all
: secondaries wires OPEN. (all disconnected from
: anything) and see (as Norn noted) if the
: transformer overheats. You'll know in about 2 mins.
: 4. Remember the voltage across the secondary
: of a transformer is always AC. You ought
: to read anywhere from 80-120 VAC. May be
: higher.
: Please report your progress and good luck.
: Phil Sussman
: Clayton, Ohio
: PS. Bubbling, gurgling, smoke, bad smells,
: heating, or dripping wax from your
: transformer are not good signs.
: : Hi Steve
: : I don't have your schematic but there is an easy way to check the power transformers. Disconnect the rectifier diodes and turn on the power. If the transformers put out any voltage and do not heat, they are good. A bad transformer will have a shorted winding and overheat is a few minutes.
: : If your transformer is putting out 80 volts and not overheating, it is good.
: : Norm
: : : Happy new year all,
: : : I am repairing a Legend guitar tube amplifier for a friend and would like some advice. This is a Legend Model G1250 SC amplifier with 3 12AX7A tubes, and diodes and transistors. My friend had it previously evaluated by a repair shop and was told that the power transformer was 'bad.' There are 2 power transformers and the higher voltage rectified one is only putting out 80 volts DC to the plates of the tubes. But, I don't have a schematic to tell me the proper voltage to apply to these tubes - it can be 200 V or 280 V DC. So, I don't know what rating transformer to recommend that he purchase; and, I don't know if there is a voltage doubling DC power supply circuit that has a bad diode that would be simplier to fix.
: : : Is anyone familiar with similar amplifier designs, or does anyone have a schematic I can borrow?
: : : Thanks, Steve
: Thanks, Steve
Next, I'll check the rectifier diodes and power capacitors, and then the other power transformer. It might have fuses; never thought of that.
Steve
