stancor # A 3852
1/3/2000 7:43:05 AMELMER LAKATA
CAN ANYONE PROVIDE SPECS FOR A STANCOR TRANSFORMER
# A 3852....IT'S USED IN A MOTOR CONTROL CICUIT AND
IT HAS AN OPEN WINDING....I'M SURE IF I HAD THE SPECS
I COULD COME UP WITH A SUBSTITUTE...THANK YOU...ELMER
1/3/2000 10:43:31 AMNorm Leal
Hi Elmer
The Stancor A 3852 is an universal output transformer. Primary 4000 to 14000, push-pull to a Secondary of .05 to 122 ohms impedance. The primary can carry 40 ma current and its rated at 18 watts. These transformers would normally be used to drive speakers in radios.
: CAN ANYONE PROVIDE SPECS FOR A STANCOR TRANSFORMER
: # A 3852....IT'S USED IN A MOTOR CONTROL CICUIT AND
: IT HAS AN OPEN WINDING....I'M SURE IF I HAD THE SPECS
: I COULD COME UP WITH A SUBSTITUTE...THANK YOU...ELMER
3/8/2002 9:15:46 PMJohn
If u are still looking - I just recently replaced the same transformer in an old Chevy radio with a Hammond 125E.
John
: Hi Elmer
: The Stancor A 3852 is an universal output transformer. Primary 4000 to 14000, push-pull to a Secondary of .05 to 122 ohms impedance. The primary can carry 40 ma current and its rated at 18 watts. These transformers would normally be used to drive speakers in radios.
: Norm
: : CAN ANYONE PROVIDE SPECS FOR A STANCOR TRANSFORMER
: : # A 3852....IT'S USED IN A MOTOR CONTROL CICUIT AND
: : IT HAS AN OPEN WINDING....I'M SURE IF I HAD THE SPECS
: : I COULD COME UP WITH A SUBSTITUTE...THANK YOU...ELMER
