You can also use an electro-dynamic speaker, but you will need a way of powering the field coil.
:You can also use an electro-dynamic speaker, but you will need a way of powering the field coil.
:T.
thank you... I do remember seeing a Peerless and maybe an RCA. I recall reading that some of the voice coils in the electro dynamic speakers were part of the filter choke and that they should never be powered up without a speaker. Or at least I think that was the warning I got with an Atwater Kent. thanks again
The main trouble with powering up a radio that requires an electro-dynamic speaker when you don't have the speaker connected, is a possible radio overload. Some radios, especially the earlier ones from the early 1930s and prior, have the field coil wired ACROSS the power supply (just as the radio is wired). With this set-up, the field coil is part of the load across the supply. With its absence, there is less of a load, sometimes causing dangerously excessive voltage to reach the other radio components.
When the field coil is wired IN SERIES with the power supply (between it and the radio), there is not as much of a danger when operating the radio without the speaker. Usually with this set-up, when the speaker is removed, the circuit between the radio and the power supply is opened, which simply causes the radio to not function at all. When variations of this circuit are used, there may be more of a danger of burning something out, depending on how the circuit is wired.
