:Does this change when you reverse the line cord?
Now, if you reverse the line cord so that the switch feeds from the "hot" side, your radio will hum when it is on. THe reason is the same as before, only all the grid circuits that are at the same potential as the switch will be directly fed from the hot side. The chassis will be at the ground or "cold" side. The opposite phase of the chassis will radiate a signal into the grids of the audio tubes and the radio will hum while it is playing. If you turn the radio off, it will now cease to hum. With the switch open, the hot side is disconnected from the radio. All circuits are fed from the cold side through the tube filaments. They will then be at the same 60 cycle alternating current potential as the chassis, and no signal will be imposed upon the grids.
Certain circumstances can also bring on this condition with AC sets, but it is not as problematic. Placing a condenser from the chassis to the line cord and then having this side of the line plugged in so that it is hot will cause this hum. The simple remedy is to reverse the line cord.
The problem you have with your AC-DC set is not really a problem, but perhaps an annoyance. As a rule it is not a good idea to ground an AC-DC set even though the chassis is isolated from the line cord by a condenser. Still, in many radios a condenser is placed across the line cord to eliminate radio interference. There is no more chance of the condenser to your chassis shorting out than there is of this condenser shorting out. Under the right circumstances, both would cause the same result--a shorted line cord (blown house fuse). It is not necessary, however, to ground by wire an AC-DC chassis. The condenser to the line cord affords enough grounding.
The problem I described above can perhaps be described with much more technical detail than I have used, which may paint a clearer image in your mind.
It is somewhat normal for amplifiers of any make to hum when turned off by the power switch if the volume control is able to be left in the medium to high position.
