EICO Model 625 Tube Tester
4/15/1998 8:16:35 PMDave Maunder
I have an EICO Model 625 Tube Checker, but no operating manual.
The roll chart shows some of the "up/down" selector switch settings underlined.
Can anyone tell me what the underlined numbers mean?
4/22/1998 2:16:34 AMWarren Parks
Below is a section scanned from the owner's manual for the Eico 625 Tube tester, reqaurding the underlined UP/DOWN numbers found on the roll chart.
REVISED PROCEDURE FOR "SHORT" TESTING, "OPEN ELEMENT" TESTING, & "FILAMENT
Note that the test procedure that follows must be performed before the MERIT test on any tube or section of a tube to eliminate the possibillity of damage to the tube tester by MERIT testing an internally shorted tube.
1, Set levers for the MERIT test (or the first MERIT test if the tube has more than one section and therefore receives more than one MERIT test),
2, If there is a short indication (neon SHORT lamp glows steadily) at this point, the tube is internally shorted and should be discarded. If there is no short indication, proceed as follows:
3, One by one move each UP lever to DOWN and back to UP, then move each DOWN lever to UP and return. Do not move the levers that were left in the center position. Levers not underlined on the roll chart should not show short at the opposite position. Levers underlined should show short at the opposite position. A short indicator on a lever not underlined means the tube is defective because of an inter-element short. Failure to obtain the short indication on an underlined lever means the tube is defective due to an open element (includes filament dlscentinulty), (Note: A momentary flicker of the neon short lamp on moving a lever through a position is not significant,
4, Repeat steps 1, 2 and 3 "or each section of a multi-section tube before MERIT testing each section,
I.E. 1065 EICO Electronic Instrument Co, lnc., 131-01 39th Ave., Flushing, N,Y, 11352
Stop by my Antique Radio Restoration Page!
http://www.verinet.com/~park7963/radio.html
10/27/1999 12:21:52 PMmatt
: Below is a section scanned from the owner's manual for the Eico 625 Tube tester, reqaurding the underlined UP/DOWN numbers found on the roll chart.
: REVISED PROCEDURE FOR "SHORT" TESTING, "OPEN ELEMENT" TESTING, & "FILAMENT
: Note that the test procedure that follows must be performed before the MERIT test on any tube or section of a tube to eliminate the possibillity of damage to the tube tester by MERIT testing an internally shorted tube.
: 1, Set levers for the MERIT test (or the first MERIT test if the tube has more than one section and therefore receives more than one MERIT test),
: 2, If there is a short indication (neon SHORT lamp glows steadily) at this point, the tube is internally shorted and should be discarded. If there is no short indication, proceed as follows:
: 3, One by one move each UP lever to DOWN and back to UP, then move each DOWN lever to UP and return. Do not move the levers that were left in the center position. Levers not underlined on the roll chart should not show short at the opposite position. Levers underlined should show short at the opposite position. A short indicator on a lever not underlined means the tube is defective because of an inter-element short. Failure to obtain the short indication on an underlined lever means the tube is defective due to an open element (includes filament dlscentinulty), (Note: A momentary flicker of the neon short lamp on moving a lever through a position is not significant,
: 4, Repeat steps 1, 2 and 3 "or each section of a multi-section tube before MERIT testing each section,
: I.E. 1065 EICO Electronic Instrument Co, lnc., 131-01 39th Ave., Flushing, N,Y, 11352
: Stop by my Antique Radio Restoration Page!
: http://www.verinet.com/~park7963/radio.html
Does anyone have any instructions for an eico 667????
10/31/1999 9:03:22 AMx
: : Below is a section scanned from the owner's manual for the Eico 625 Tube tester, reqaurding the underlined UP/DOWN numbers found on the roll chart.
: : REVISED PROCEDURE FOR "SHORT" TESTING, "OPEN ELEMENT" TESTING, & "FILAMENT
: : Note that the test procedure that follows must be performed before the MERIT test on any tube or section of a tube to eliminate the possibillity of damage to the tube tester by MERIT testing an internally shorted tube.
: : 1, Set levers for the MERIT test (or the first MERIT test if the tube has more than one section and therefore receives more than one MERIT test),
: : 2, If there is a short indication (neon SHORT lamp glows steadily) at this point, the tube is internally shorted and should be discarded. If there is no short indication, proceed as follows:
: : 3, One by one move each UP lever to DOWN and back to UP, then move each DOWN lever to UP and return. Do not move the levers that were left in the center position. Levers not underlined on the roll chart should not show short at the opposite position. Levers underlined should show short at the opposite position. A short indicator on a lever not underlined means the tube is defective because of an inter-element short. Failure to obtain the short indication on an underlined lever means the tube is defective due to an open element (includes filament dlscentinulty), (Note: A momentary flicker of the neon short lamp on moving a lever through a position is not significant,
: : 4, Repeat steps 1, 2 and 3 "or each section of a multi-section tube before MERIT testing each section,
: : I.E. 1065 EICO Electronic Instrument Co, lnc., 131-01 39th Ave., Flushing, N,Y, 11352
: : Stop by my Antique Radio Restoration Page!
: : http://www.verinet.com/~park7963/radio.html
: Does anyone have any instructions for an eico 667????
6/2/2000 1:33:05 AMRandy Carrero
Hello
I am Randy
I'm form to Caracas,Venezuela
I don't writing very well.
I need a information the a Test Equipment calibration.
The sign is Eico and the application: TESTER & REJUVENATOR
Mode is EICO 632 CRT.
If they have this informations, i need in spanish pleace.
Thank a lot.
Randy Carreo
5/10/2001 12:54:13 AMJAIME ANDRES QUIROGA TORRES
: : : Below is a section scanned from the owner's manual for the Eico 625 Tube tester, reqaurding the underlined UP/DOWN numbers found on the roll chart.
: : : REVISED PROCEDURE FOR "SHORT" TESTING, "OPEN ELEMENT" TESTING, & "FILAMENT
: : : Note that the test procedure that follows must be performed before the MERIT test on any tube or section of a tube to eliminate the possibillity of damage to the tube tester by MERIT testing an internally shorted tube.
: : : 1, Set levers for the MERIT test (or the first MERIT test if the tube has more than one section and therefore receives more than one MERIT test),
: : : 2, If there is a short indication (neon SHORT lamp glows steadily) at this point, the tube is internally shorted and should be discarded. If there is no short indication, proceed as follows:
: : : 3, One by one move each UP lever to DOWN and back to UP, then move each DOWN lever to UP and return. Do not move the levers that were left in the center position. Levers not underlined on the roll chart should not show short at the opposite position. Levers underlined should show short at the opposite position. A short indicator on a lever not underlined means the tube is defective because of an inter-element short. Failure to obtain the short indication on an underlined lever means the tube is defective due to an open element (includes filament dlscentinulty), (Note: A momentary flicker of the neon short lamp on moving a lever through a position is not significant,
: : : 4, Repeat steps 1, 2 and 3 "or each section of a multi-section tube before MERIT testing each section,
: : : I.E. 1065 EICO Electronic Instrument Co, lnc., 131-01 39th Ave., Flushing, N,Y, 11352
: : : Stop by my Antique Radio Restoration Page!
: : : http://www.verinet.com/~park7963/radio.html
: : Does anyone have any instructions for an eico 667????
12/28/2004 8:42:02 AMraymond
:I have an EICO Model 625 Tube Checker, but no operating manual.
:The roll chart shows some of the "up/down" selector switch settings underlined.
: Can anyone tell me what the underlined numbers mean?
12/28/2004 10:41:09 AMNorm Leal
Hi Raymond
The manual is available here:
http://www.nostalgiaair.org/References/Manuals/
::I have an EICO Model 625 Tube Checker, but no operating manual.
::The roll chart shows some of the "up/down" selector switch settings underlined.
:: Can anyone tell me what the underlined numbers mean?
