majestic 15a schematic help
5/11/2005 3:16:28 AMbutch s.
hi in this set the first if can has 3 windings on a coil form then inside of that there are 2 more windings which are toast wound on a wood dowel one has a 2k res. going to it the other goes to a grid on the 35/51 i can't count the windings and there is no ohm rating on these and i'm not sure of their purpose. is rewinding critical on these they look to have been the same diameter but its hard to tell on such small wire it measures a little over .oo3 on my micrometer.should i give up and try to find the if assembly somewhere ? i have never had replies to adds like these, or just keep rewinding coils till i get it right if i had a grid dip meter would it help check out the coils?butch
5/11/2005 9:45:04 PMNorm Leal
Hi Butch
Check here for a replacement:
http://www.oldradioparts.com/2a6fla.txt
If you don't see what you need give Gary a call. That might be the oscillator you are describing? If so inductance needs to be close or tracking will be off.
Beitmans 1926-1938 has Majestic Model 15 & 15B on page 80. Might be same as 15A.
:hi in this set the first if can has 3 windings on a coil form then inside of that there are 2 more windings which are toast wound on a wood dowel one has a 2k res. going to it the other goes to a grid on the 35/51 i can't count the windings and there is no ohm rating on these and i'm not sure of their purpose. is rewinding critical on these they look to have been the same diameter but its hard to tell on such small wire it measures a little over .oo3 on my micrometer.should i give up and try to find the if assembly somewhere ? i have never had replies to adds like these, or just keep rewinding coils till i get it right if i had a grid dip meter would it help check out the coils?butch
5/11/2005 10:22:40 PMbutch s.
:Hi Butch
: Check here for a replacement:
:http://www.oldradioparts.com/2a6fla.txt
: If you don't see what you need give Gary a call. That might be the oscillator you are describing? If so inductance needs to be close or tracking will be off.
: Beitmans 1926-1938 has Majestic Model 15 & 15B on page 80. Might be same as 15A.
::hi in this set the first if can has 3 windings on a coil form then inside of that there are 2 more windings which are toast wound on a wood dowel one has a 2k res. going to it the other goes to a grid on the 35/51 i can't count the windings and there is no ohm rating on these and i'm not sure of their purpose. is rewinding critical on these they look to have been the same diameter but its hard to tell on such small wire it measures a little over .oo3 on my micrometer.should i give up and try to find the if assembly somewhere ? i have never had replies to adds like these, or just keep rewinding coils till i get it right if i had a grid dip meter would it help check out the coils?butch
thanks for the reply norm i will check out that site.butch
5/11/2005 11:03:55 PMbutch s.
:Hi Butch
hi again he has one listed but it says you need to order at least thirty bucks worth so i threw in a few tubes i need and emailed him it had 2 listed so hopefully he has one.thanks again .butch
