It is not affected by the volume control so I guess that eliminates the RF and IF sections.
Could this be caused by a rectifier tube starting to go bad? Or an audio output tube maybe? I'd answer my own question if I had a replacement tube on hand, but since I don't I'm asking here.
I tend to think that it is not anything inductive right now (like placement of a wire or part under the chassis) because nothing under the chassis has been moved since I got it working and the problem is new in the last few days.
Any ideas?
Check your electrolytics anyway, even if they are new. Be sure that the needle on your resistance meter goes all the way up to zero. On any condenser above 1 MFD, it should. Be sure that the needle goes all the way back down. Be sure that you didn't install the electrolytics backwards. Sometimes you can do this and nothing bad will happen initially, though usually a lot happens (blown rectifier and resistors). Eventually, however, trouble will result even if it didn't initially. Slowly the electrolytic will start to short out. Also, if you installed electrolytics rated at too low of a voltage (less than 150 volts), they may work initially, but then break down and cause hum and eventually havvoc. Usually they overheat right away and blow up, but not always. If you're not new to repairing tube type radios, then you probably already know about all of this, but if you are, I just thought I'd mention it. It's a good idea to check everything out anyway, as even the experienced make simple mistakes.
If it isn't a DC hum, or perhaps even if it is, the 1st amplifier tube or the output tube may have developed a heater to cathode leak. The rectifier may have even developed such a leak. If the rectifier develops such a leak, it can cause both hum and electrolytic distruction if severe. It will ruin the electrolytics eventually even if they aren't ruined initially. This problem is the same as having a solid state rectifier that leaks reverse current.
Another thing that can cause DC hum as well as AC hum is how the low end of the volume control is connected to B-. This usually is a problem from the start, however, and does not develop with time. Certain radios can be picky when the low end of the volume control is connected too close to the line cord. The line cord is B-, but too much fluctuation exists here. Connecting the low end of the control to a part of B- somewhere else in the radio reduces this problem (using a resistor capacitor connection to B- helps sometimes, too). I would count this out for now, though. It's a freak issue, and like I said, it's usually a problem from the start.
:If it is the normal DC type of hum, if you used new electrolytics, then they are likely still good. If you used old electrolytics that were good at the time, one may be starting to fail. A short in the output tube cathode condenser (if any is present) will increase hum. A failing tone condenser will cause hum sometimes. If the set uses a solid state rectifier, the rectifier can start to leak reverse current, which will cause both hum and eventually destroyed electrolytics. Since you say that there is a tube rectifier, though, this problem is probably not possible.
:Check your electrolytics anyway, even if they are new. Be sure that the needle on your resistance meter goes all the way up to zero. On any condenser above 1 MFD, it should. Be sure that the needle goes all the way back down. Be sure that you didn't install the electrolytics backwards. Sometimes you can do this and nothing bad will happen initially, though usually a lot happens (blown rectifier and resistors). Eventually, however, trouble will result even if it didn't initially. Slowly the electrolytic will start to short out. Also, if you installed electrolytics rated at too low of a voltage (less than 150 volts), they may work initially, but then break down and cause hum and eventually havvoc. Usually they overheat right away and blow up, but not always. If you're not new to repairing tube type radios, then you probably already know about all of this, but if you are, I just thought I'd mention it. It's a good idea to check everything out anyway, as even the experienced make simple mistakes.
:If it isn't a DC hum, or perhaps even if it is, the 1st amplifier tube or the output tube may have developed a heater to cathode leak. The rectifier may have even developed such a leak. If the rectifier develops such a leak, it can cause both hum and electrolytic distruction if severe. It will ruin the electrolytics eventually even if they aren't ruined initially. This problem is the same as having a solid state rectifier that leaks reverse current.
:Another thing that can cause DC hum as well as AC hum is how the low end of the volume control is connected to B-. This usually is a problem from the start, however, and does not develop with time. Certain radios can be picky when the low end of the volume control is connected too close to the line cord. The line cord is B-, but too much fluctuation exists here. Connecting the low end of the control to a part of B- somewhere else in the radio reduces this problem (using a resistor capacitor connection to B- helps sometimes, too). I would count this out for now, though. It's a freak issue, and like I said, it's usually a problem from the start.
:Thomas
:A DC hum buzzes like the buzzer on an old Telechron alarm clock. It sounds like when the electrolytics go bad. An AC hum, usually caused by stray signals getting into the audio grids, sounds different, and I can't explain it other than it sounding kind of of "nare"-ish. The hum when you touch the grid of an audio tube may be a loud blaaat, which is a DC hum, and is caused by the tube rectifying the AC in your finger (your body picks up stray AC signals in your home from the wiring), or may be a "nare" sound if the signal is not strong enough for the tube to rectify.
:Thomas
:Thomas
:If I can beg/borrow/buy a scope, wouldn't it be possible to measure the frequency of the hum on the output to the speaker to determine if its 60 or 120?
:Larry
::A DC hum buzzes like the buzzer on an old Telechron alarm clock. It sounds like when the electrolytics go bad. An AC hum, usually caused by stray signals getting into the audio grids, sounds different, and I can't explain it other than it sounding kind of of "nare"-ish. The hum when you touch the grid of an audio tube may be a loud blaaat, which is a DC hum, and is caused by the tube rectifying the AC in your finger (your body picks up stray AC signals in your home from the wiring), or may be a "nare" sound if the signal is not strong enough for the tube to rectify.
::Thomas
:You know Marv, wouldn't it be awesome if someone made a signal generator program? Then you could always be sure that the frequency was right on. Anyone could align a radio without having to resort to an old drifty generator or a very expensive new generator (of course the program could be expensive, too). The only problem would be if someone's computer didn't match the sample rate or whatever you call it. My computer currently has this problem, and so all music sounds like chipmunks. Haven't figured out how to fix it, yet. I've looked everywhere.
:Thomas
:I have a post war radio that I restored about 3 months ago that has recently developed a low hum. The restoration included the usual stuff. It was recapped (including the electrolytics), replaced out-of-tolerance resistors, and was re-aligned. The other day I noticed a low hum that wasn't there before. The hum isn't really intrusive at normal listening levels, but I can tell it is there and with the volume turned completely down, it is very apparent.
:It is not affected by the volume control so I guess that eliminates the RF and IF sections.
:Could this be caused by a rectifier tube starting to go bad? Or an audio output tube maybe? I'd answer my own question if I had a replacement tube on hand, but since I don't I'm asking here.
:I tend to think that it is not anything inductive right now (like placement of a wire or part under the chassis) because nothing under the chassis has been moved since I got it working and the problem is new in the last few days.
:Any ideas?
