Carl
With your radio this may not matter, but it is generally best to adjust the high end of the dial first. This is done by adjusting the oscillator trimmer condenser for the A band so that the designated frequency given in your alignment data will fall on its mark on the dial. Then adjust the low end of the dial with the slug by tuning the dial to 600 KC and then adjusting so that 600 KC comes in on its mark. Check both ends of the dial for aligment and sensitivity. Unless both ends are aligned properly, synchronization will be a problem all over the dial in certain places, and sensitivity may be a problem at the low end of the dial. With some sets, achieving good results all over the dial is difficult without much readjustment. It is best, then, to go for a balance between maximum sensitivity at 550-600 KC and good alignment all over the dial.
Generally I use a signal generator for the IF alignment, and actual stations for the oscillator alignment, as they are usually more accurate than my signal generator.
Here is the SD:
http://www.nostalgiaair.org/PagesByModel/183/M0015183.pdf
Carl
