Looking at the plate of the 6A8 with a scope I can see rf but fades away to nothing if I tune the tuning knob back and forth either way very far.
With the condenser disconnected from the circuit, check for shorts by connecting a meter to the stator and rotator plates and moving the part through its range of motion. If you detect a short in this manner, you may be able to verify its location by sliding the business card (or other suitable insulator) in there to see if the RF then returns. Just make sure not to spread the blades too far and create a different short.
If the blades are OK, it is also possible that in certain positions, the bearings of the tuning condenser are interfering with the grounding of the movable blades. Not sure how you would fix this but its another possibility.
Randy
:This radio is just dead. No station sound. If I disconnect the cap lead to the 6A8 and put a long wire there instead, then I can hear stations but not real clear, not bad though. What could be wrong??
:Looking at the plate of the 6A8 with a scope I can see rf but fades away to nothing if I tune the tuning knob back and forth either way very far.
I have found that sometimes the yellow dirt and grime can cause trouble even when there are no obvious shorts. Because of this, it is important to have a clean condenser. Once the condenser is clean, you will enjoy its looks anyway, and you will want to make the entire chassis look just as fine.
Of course if you didn't think of this already, be sure to dispose of mineral spirits and rags soaked with mineral spirits appropriately (out-of-doors). Do not get any of the above near your oven or furnace or water heater.
Thanks again,
John
:It is a very good idea when a tuning condenser is dirty, to clean the condenser well and then re-lubricate it. Use very hot water and detergent. First put dish detergent all over the condenser and allow it to soak in. Then take a tooth brush and gently scrub everywhere including between the plates. Then rinse in hot water very well. Then dip in a bath of mineral spirits to remove other oils and dirt missed by the soap. Use a tooth brush here as well. Then wash again with soap and water. Dry in the oven at 200 degrees. Allow the oven to come up to temperature once. Then, when the flame (or electric coil) goes out, turn off the oven. This is just the right amount of heat for drying the condenser. Some condensers do not require the mineral spirits treatment. If the condenser comes clean with just soap and water, omit the mineral spirits. Once the condenser is thoroughly dry, check with a meter for shorts. Grease the ball bearing with di-electric or servo grease. Also grease the bearing at the other end and the contact springs, if any. You may rub the frame down with a thin layer of motor oil by hand if you wish--use a thin film on your fingers only; no more. This will retard tarnishing of the nickel finish to some degree. Do not get oil on the plates or insulators or trimmers.
:I have found that sometimes the yellow dirt and grime can cause trouble even when there are no obvious shorts. Because of this, it is important to have a clean condenser. Once the condenser is clean, you will enjoy its looks anyway, and you will want to make the entire chassis look just as fine.
:Of course if you didn't think of this already, be sure to dispose of mineral spirits and rags soaked with mineral spirits appropriately (out-of-doors). Do not get any of the above near your oven or furnace or water heater.
:Thomas
