A gassy or weak tube can cause it to "pop" out of operation. A leaky or shorted condenser, whether mica or paper, is easily tested on your multi-meter on its most sensitive setting. Remove the condenser from the circuit first. An open condenser is, however, only easily found by replacement.
The second method is to use your signal generator as a signal source for a working radio. Keeping the generator at a low output so as to not actuate the AVC, you may place a condenser in series with the generator and check output at the speaker. Test against a known good condenser in new condition. Unless your radio is adequately shielded, however, this test may be inaccurate due to the signal getting to the radio through the air.
Both of these test methods, especially the second one, are a little over the top, however, and so you are probably better off just purchasing new condensers and trying them, or purchasing a condenser tester.
